Question about Cell Phones
When i switch on the hand phone it's going hot
    Problem Solver:
  • 6 Answers
You have to change it battery and charger, it is also possible that some wire is displaced prom it place.
Posted on Aug 06, 2010
Phone switching itsself off all the time
I'm going to ask you a few question, there is no need for you to answer, but for you to troubleshoot on the phone.
1. Does the battery show fully charge when done charging or does it show some percentage?
2. Are you using a GS2 from T-Mobile or AT&T?
3. Does the phone too hot even when not in use?
4. Does the phone lag when you use it?
Once done with that, try the following, place your phone upward on a flat surface, or you can hold it in your hand with the display facing you. Run your finger ever so gently over the power key from top to bottom. If ny any chance the phone turn it self off, by sliding your finger and not pressing on it, then you have a faulty power key.
Check your phone and TS with these question, then get back to me with model, ROM,
Mar 11, 2014 | Samsung Cell Phones
My hand held little steamer will not get hot. switch comes on, but that is all it does
If the switch isworking then the only possible fact is that the heating element has failed and it might be too costly for a change.
Jun 10, 2013 | Ingenious Designs, Llc My Little Steamer...
I have a Samsung Messager II, just recently the phone has been acting erratic, opening the internet on its own, switching widgets randomly and not accepting inputs. I'm thinking it might have...
Remove the battery and reboot the device to attempt to resolve specific issues (phone not taking inputs)
Perform a factory reset by going to the phone settings if issues continue. make sure to back up personal information before hand.
as a last resortTake the device into your carriers store and have a service representative look at it, your device may be defective or damaged.
Jun 15, 2011 | Cell Phones
Ive installed it and it still doesnt work
Did you take out the same set up as the switch /outlet you have now? Does the light work? Or did it work before you put the switch in? Do you have the black wire, line, to the brass screw on the receptacle? The white wire on the silver screw? The switch should have 2 black wires attached to it, doesn't matter which side. One should be hot. Get out the tester and check that, you should have 2 hot/ black wires in there, one feeds the switch, one feeds the receptacle, the white wire is neutral and the other colored wire, black wire should be dead, going to the light, it will be hot when the switch is thrown. Check it out, hope this helps.
Feb 14, 2011 | Leviton 5225WSP Switch and Outlet
We can't get the Leviton 5225 combination switch and receptacle to work independently of each other., We broke off the metal tab between the 2 black screws, not we think that was wrong. I think we need...
You have switch combo.
Screws are color-coded.
Dark screws, brass screw, silver screw.
Break-away fin is located between dark screws.
1) Connect the dark screws again using jumper wire
2) Electricians don't guess, they test
Separate wires for testing. Do not untwist any wires that are twisted together. Note which wires were connected on same screw on previous device.
Tape tester leads to wood sticks to keep hands away from power
Turn power ON
Test each wire to bare ground wire.
Tester lights up on Hot wire. Hot connects to dark screw.
Hot is identified.
Test Hot to all other wires, except bare ground.
Tester lights up on Neutral. Neutral connects to silver screw.
Final wire goes to Load (light, fan, motor). This wire connects to brass screw.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 24, 2011 | Leviton 5225WSP Switch and Outlet
Insatllation
You have switch-plug combo.
1) Screws are color-coded.
-Separate wires for testing. Do not untwist any wires that are twisted together. Note which wires were connected on same screw on previous device.
-Tape tester leads to wood sticks to keep hands away from power
-Turn power ON
-Test each wire to bare ground wire.
-Tester lights up on Hot wire. Hot connects to dark screw.
-Hot is identified.
-Test Hot to all other wires, except bare ground.
-Tester lights up on Neutral. Neutral connects to silver screw.
-Final wire goes to Load (light, fan, motor). This wire connects to brass screw.
Jan 24, 2011 | Leviton Decora Combination Switch - 5625-I...
I have a black/white/ground wire coming from my power supply into my bathroom. I want to install a 274w combination device so as I can have one plug outlet and a switch for the shower fan.I need to see a...
1) In this situation we need to test the wires.
Electricians don't guess, they test, and a diagram would be guessing which wire color does what.
2) FYI: non-GFCI receptacle located in bathroom is not code, and device will have to be replaced when property is sold. The reason for GFCI is the likelihood of you holding defective electrical gizmo from China in one hand while putting other hand in running water. Or electrical gizmo falling into bathtub occupied by wife with large life insurance policy.
If you have kids using that bathroom, I want you to avoid using non-GFCI device.
3) Your new device has color-coded screws: Dark, brass, and silver.
These colors tell electrician how to wire the device.
4) Let's test to see which wire connects to which screw:
Separate wires.
Use ordinary 2-wire tester from hardware store.
Tape tester leads to wood sticks so hands are away from power.
Turn power ON.
Tester lights up on Hot wire. Hot wire connects to dark-colored screw on device.
Hot wire is identified.
Test Hot wire to all other wires in box, except bare ground wire.
Tester lights up on Neutral wire. Neutral wire connects to silver screw, and will complete circuit to receptacle.
If box does not have a Neutral wire, the circuit to receptacle can be completed using ground wire on silver screw, but I am not recommending that.
Last wire goes to Load (light, fan, motor). Load wire connects to brass screw, and will complete circuit to Load.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on electrical device.
Leviton and Lutron both make GFCI switch-outlet combo.
Buy at Home Center or on-line
Leviton 7299
http://www.amazon.com/Leviton-7299-NI-15-Amp-125-Volt-Combination/dp/B000UJADW6
Jan 02, 2011 | Cooper Industries Cooper Wiring 274W...
No battery backup
then dont charge the battery too long and charge for daily one hour. and the battery may be damaged that so you get the heat problem
Sep 21, 2009 | Nokia E51 Cellular Phone
My nokia 3110 does not switch on if there is a sim inserted..
Your sim Ic is Short Circuit, its located near the sim reader on the PCB board, You will nead a steady hand a Hot Air station for this repair. The ic is gray shine looks like glass cant miss it
May 13, 2009 | Nokia 3110 Cellular Phone
Red light won't go out
If the indicator light you are referring to is the 'surface hot' light then the element has failed. Each element contains a sensor to detect when the element is hot, these sensors fail. The element will have to be replaced. If there is only one light to indicate hot surface, you will have to determine which element has failed.
If the indicator light you are referring to is the 'element on' light then the corresponding control switch has failed. Each control switch contains a switch that will illuminate a lamp to indicate a burner is on. This switch has probably stuck closed.
Jun 21, 2008 | Whirlpool RF365 Electric Kitchen Range
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
