Question about Pool & Spa
I need an instruction manual for Lite2 pool heater, Jandy H0260100A, new home owner, was not left instruction manual thanks
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
I believe this is the correct one. If not, select the correct version from those found on Jandy's site here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 06, 2010
Jandy lite2 pool heater
shorted temp sensor un plug the two black wires on control board should stop flashing if it does replace temp sensor
May 24, 2013 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Jandy lite2 lg175 pool heater will not remain lit where is the flame sensor located?
follow small black wire down from board next to ignitor in box or ignitor on burner clean up then try again
Aug 19, 2012 | Jandy Laars Lite2 Ld 175,000 Btu Heater
I am getting an FL 2 error code on my jandy lite2. I changed the flame sensor and still get same error message
Look at the list of codes inside the cover of the heater. Your owners manual should have a complete remede for all codes.
May 27, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
How to fox flo 6 problem on Jandy lite2 175n pool heater
possible was the wron one I assume was the same one clean the filter clean the basket check for clog impeller
Jun 28, 2009 | Jandy Laars Lite2 Ld 175,000 Btu Heater
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Solution for Jandy Lite 2 Pool Heater display flashes on & Off ..
Can a model LJ250P Propane 2005 model be installed indoors . The rating plate says it can. But manual says it cannot. What the hell????
Jun 06, 2009 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Pool & Spa Logo
161 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
