Question about Troy-Bilt Pony Garden Tiller
Tiller ran great then backfired through exhaust and stoppped. the tiller will not start, lots of gas and spark, what should be done ?
2 Suggested Answers
  • 36 Answers
SOURCE: Troy Bilt Rear tine tiller model 643 Bronco, won't
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Posted on Jun 05, 2010
What is causing steam from my exhaust pipe and bike won't stay running?
It's probably dirt in the carbs and the steam is the un burnt fuel from a stuck needle valve in the carb
Oct 05, 2014 | Honda NSR 250 MC 21 Motorcycles
Managemylife
Crank engine a few times. If spark plug is dry carb needs dismantling and cleaning. Probably gummed up.
Jul 10, 2014 | Craftsman 4-Cycle Mini Tiller
Poulan snowblower won't start; it backfires and sometimes starts but only lasts a few minutes if lucky; I've replaced spark plug and gas.....no luck
Gotta take the Bowl off the carburetor and see if the Jet is Plugged up.
Today's Ethanol gas ills carburetors. New gas wont help a gummed up carb from leftover old gas.
Dec 30, 2013 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Husqvarna weedwacker
Check the exhaust isnt blocked, they contain a gauze which can degrade and cause problems with the exhaust gas flow.
Jul 30, 2012 | Husqvarna 323L
Backfiring through throttle body on hot start up
Hi Anonymous, popping, coughing, spitting, or backfiring through the carburator is usually caused by air getting sucked in combustion chamber do bad intake seals leaking. Leaking exhaust gaskets can also be suspect. Remove air cleaner and backing plate, while engine is idling spray WD-40 or Brake Kleen around intake manifold to head area, if RPM's increase you have an intake leak and seals need to be replaced, also spark plugs will be burning whiter than normal. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 18, 2012 | 2007 Harley Davidson FLSTC Heritage...
I have a 95 Road King that isn't running right, it
Backfiring out of the exhaust is usually an ignition problem. Unburned fuel is getting into the exhaust system because it's not being ignited in the cylinder. When the engine fires on that cylinder again, it ignites the raw fuel in the exhaust causing the pop that people call a backfire. I'd investigate the ignition system. Connect a timing light to each of the spark plug wires if it has a single fire ignition or either of them if the ignition system is the stock dual fire. Start the engine and watch the timing light to tell if the engine is missing as the light will miss a flash.
Good Luck
Steve
Jun 05, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
The tiller bogs down, loss of power.
I have had same problem. First time, I sent it out for fixing. They told me exhaust was clogged. They clean and it ran great. From then on, I started cleaning exhaust and intake myself. Also found manual online, which helped a lot. I've since then found out that the Mantis motors are similar (or a branch off) of Echo. So many parts are similar to their gas blower pack. Home Depot had a kit that had spark plug, air filter, and fuel filter in it all for ~$12. Had to tear off rubber from around air filter, but other than that had it running great in no time. I've also learned since finding the manual online, that the gear box should be checked/lubed each year, and also how to reseat motor on drive shaft, if slips off.
Good luck
Dan
Mar 09, 2009 | Mantis Tiller
Samurai backfire
It sounds more like a timing problem. If it backfires through the carb that means the intake valve is open when the spark plug fires. Same with the exaust but it the exhaust valve that is open.
Dec 14, 2008 | 1986 Suzuki Samurai
Troy-Bilt Pony Garden Tiller Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
