Question about Kyocera Copystar CS-1635 Copier
When powered on it displays error C -6 blinking, then it displays 000.
  • 113 Answers
Press 1087 1087 the display will show U000 the press 163 and press start , display shows CLE press start again the error will be cleared
Posted on Aug 30, 2010
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
Error
E000007-0000 code is Fixing Film error.
FM2-3346-000
1 FIXING FILM ASSEMBLY 120V
FM2-3353-000
1 FIXING FILM ASSEMBLY 230V EXCEPT CN
FM2-3329-000
1 FIXING FILM ASSEMBLY 230V CN
Sep 11, 2009 | Canon iR 2016i Black and White Copier
To solve 10 raised -3, to be done with cal., answer in the display ought to be .001
The calculator has several decimal display formats: FIX, SCI, NORM and ENG.
Here are examples of calculations with different formats and how to set them.
It may be a good idea for a user to get accustomed to the scientific display format, because it is the one most calculators adopt when the result to be displayed is too large or too small--when there are not enough places on the screen to display the result.
To help you with the power of 10 notation
1 billion =1000 000 000 =1 E 09 (9 zeros after 1 >> exponent 9)
1 million=1 000 000 = 1 E 06 (6 zeros after 1 >> exponent 6
1 thousand= 1000 =1 E03 (3 zeros after 1 >> exponent 3)
One= 1 = 1 E0
One tenth = 1/10 =0.1: the 1 is ONE position after the decimal mark>> exponent -01
One hundredth =1/100 =0.01 the 1 occupies the 2ND position to the right of the decimal point, exponent -02
etc.
1/1000 =0.001 = 1E-03
1/10000=0.0001=1E-04 (1 in 4th position to the right of decimal mark)
1/1000000=0.000001 = 1E-06 (1 in 6th position to the right of decimal mark)
1E-09 =0.000000001 : the 1 is in the 9th position to the right of decimal mark.
Jul 24, 2009 | Casio FX-260 Calculator
I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Jun 17, 2009 | Televison & Video
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
Error ##334 show up on display. what is it meant exectly ?
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 – 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Replace all the Ink Absorbers.
QA4-1012-000
QA4-1013-000
QA4-1014-000
QA4-1015-000
QA4-1055-000
Reset the counter to zero.
Replace the printhead. QY6-0042-000 (now QY6-0064-000)
Should cost you about $54 if in the US.
This will only work a few times. Eventually, it will fail to reset
and you will have to replace the Printhead. I hope this helps.
Nov 13, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Error code E000051-000
E000051-000 is not a waste toner full error code thats E000015. This error code refers to the horizontal registration sensor not reaching home position or is not detected when the assembly is commanded to move. The sensors function is to determine the edge of the sheet of paper in the front to rear direction to determine the write position on the drum. It is not somthing you can fix and would require a tech. Possible sources of the error are, DC controller, horizontal registration sensor or actuator, or the horizontal registration motor. Based on experiance the motor is either stuck or burned out so the sensor does not move at start up
May 31, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
ERROR CODE E000100-0001
I did this and it did not solve the problem. What can I do?
Apr 16, 2008 | Canon imageRUNNER 5570 Copier
Kyocera Copystar CS-1635 Copier Logo
149 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
