Question about GE 30 in. JGP336 Gas Cooktop
I was cleaning the cook top and all of a sudden the ignitors began to click. I've shut the power off to the outlet. What is the issue?
  • 259 Answers
If you got moisture/ liquid in the surface ignition switches (below the knobs) they will short out (thinking they are turned on). If you allow the top to dry out, they usually will work just fine.
Some models that use auto light burners will have the same issue just from getting the burner wet as they look at the resistance from the ignitor at the burner to the cap. Same thing applies, let it dry out.
Don't waste your money on a service call, just let it dry out. It may take a day but it will dry out and be just fine.
Good luck with this!!
Posted on Aug 06, 2010
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
The electronic lighter will not quit clicking.
Hello, Thank You for using FixYa. I will be helping you today. Did you clean the cook top or spill something? If the switches get wet they will click untill it drys out. If not then one of the switches failed and would need to be replaced. Its the switch that sits on the burner valve.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 01, 2011 | Maytag Cooktops
We are having a dinner party and our 5 burner gas pro series frigidaire stove top is clicking. I tried to turn off and clean the ignitors but nothing seems to work. Please help!!!
you have a stuck ignitor switch. they are mounted just below the knobs. you cant get to them until you remove the unit and then the top.
if you spilled water or something boiled over, it could get into the switches and cause this.
if you reach under the cooktop, in you cabinet, you can just unplug it from the outlet, or try to shut off the breaker to the unit. that will stop the clicking and you can deal with the repairs after your party.
Jan 10, 2010 | Cooktops
Suddenly I hear a constant 'clicking' sound from the Maytag csg7000 cook top which I am not using right now. It's like it's trying to ignite by itself. What could be a problem?
usually this is a problem with one or more of your ignitor switches, they are found below the selector switches, below the top, if you take off the selectors you might even be able to see them,
these are what sends voltage to you ignitor, from the spark module, one one goes bad, they all tend to spark, because light one light all....
http://www.appliancepartspros.com/part_details.aspx?part_id=4101545
this link wil take you right to the part i suggest,
as well as be able to order it
since this happens alot after a boil over i would start with one of the front two burners,,,, you can order one and keep replacing them with the next till the clicking stops
Nov 04, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
One igniter won't work right on my gas cooktop.
If you're not getting the ignitor sparking (you should hear it) when you turn the burner knob on for that burner, it could be that either the ignitor is dirty or caked with some gunk and needs to be cleaned.
The other issue could be that the ignitor is faulty and needs to be replaced. If you want to confirm a faulty ignitor before ordering a new one, you can swap it out with one of the other ignitors on the cook top. Be sure to unplug the cook top from the outlet thou, to prevent getting a shock, as those little sparkers can give you a pretty good jolt!
Just remove the grates and burners to get at the ignitor for cleaning it. To get at the ignitor, youll need to go under the cabinet or counter that the cooktop is installed on in order to remove the ignitor and swap it with one of the other ones. You'll see that these are held in place with a retaining clip you can remove with a flat bladed screwdriver, etc.
If you find that the one that isn't working is faulty, you can order one from your local appliance service store, or get one online. www.searspartsdirect.com lists parts for almost every appliance there is, just enter in the full model number to get a parts list, etc.
Hope you find this Very Helpful and best regards!
Sep 09, 2009 | GE 30 in. Profile JGP932 Gas Cooktop
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Clicking gas cook top
I accidentally bumped the thing where the gas comes out (I don't know what it's called - I'm a wife not a tekkie) and it started clicking when I turned it on. I turned off the gas and repositioned that gizmo and it stopped clicking.
Feb 19, 2009 | Thermador SGS36GS Gas Cooktop
GE 30 in. JGP336 Gas Cooktop Logo
113 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
