Question about RCA Televison & Video
I have an RCA projection TV model P52937 that will not turn on, when I press the power button the red light comes on briefly, the TV makes a clicking sound 3 times and then the light goes out and the power shut s off. Any ideas?
  • Steve Sep 15, 2010
    Rylee, I need further instruction on this repair. Im not sure which board is the deflection board, and I've looked at every board and can not find any caps CP 114, 120 and 150 all of the cap numbers I find are 11345, 13678, 14944. maybe you could clarify things for me. Thanks. Steve
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
  • 9 more comments
  • Steve Aug 06, 2010
    Is there any stored High voltage in a projection set? If so what is the proper way to discharge? Also is CP 150 a 2200UF 16V cap? Thanks
    Steve
  • Rylee Smith
    Rylee Smith Aug 06, 2010
    High voltage takes an hour to discharge once the set is unplugged and yes you are right about the capacitor.
    are they all electrolytic caps? Could you give me the name of a good web site to purchase components from. Thanks Steve
  • Rylee Smith
    Thanks for your reply Steve. Please click on this link to buy parts. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Thank you Rylee, will order parts, install, and report back. May take a few days.
    Steve
  • Rylee Smith
    Thats fine Steve. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Steve Aug 13, 2010
    Sorry for the delay Rylee, I ordered my parts from the partstore.com and just received an email that I will not get the parts untill 9/9/2010. Thats rediculous! Im searching for a more reliable source and will cancle that order if I find one. Any other parts website that you know of? Thanks
    Steve
  • Rylee Smith
    Rylee Smith Aug 13, 2010
    Thanks for your reply Steve, you can buy the parts from this link. Also before ordering the parts call them up and check with them first.
    Rylee, I found both parts from Radio Shack but I have one question. The 2200uf cap has a 50V raiting, if I remeber correctly from tech school it is okay to exceed the voltage raiting. Do you agree? Also it is axial leaded but I should be able to mount it in a hairpin confinguratiuon with some shrink tube on one lead. Let me know what you think. thanks Steve
  • Rylee Smith
    Yes Steve thats fine you can use the 50v one...I mean that'll be even better
  • Steve Sep 14, 2010
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
RCA P52937 52 in. Rear Projection Television
It almost has to be a power supply problem, probably in the high voltage stages... Regulator, Horiz. Output.
Geno
Mar 01, 2008 | RCA P52937 52" Rear Projection Television
Won't turn on
hv splitter is shorted,this item is behind the speaker grill,remove the access panel,part is mounted between the left and middle tube,has red wires and black wire connected on the left,part number 205064
Jan 10, 2008 | RCA P52937 52" Rear Projection Television
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
RCA big screen TV
Replace splitter RCA #205064, Q4101, U4101, C4102, C4118, C4108
Jan 02, 2008 | RCA P52937 52" Rear Projection Television
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Nov 21, 2007 | RCA P52937 52" Rear Projection Television
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
