What is zdwyboh file in C:\WINDOWS\system32\drivers directory ?
    Guru:
  • 1,082 Answers
Best guess is it is a virus. They randomly name themselves. Run a virus scan. www.avast.com has a free online scan. Viruses sometimes block internet sites, if so, you probably will need expert help to fix this.
Posted on Aug 06, 2010
  • Jim Winger Aug 07, 2010
    Looks like they have pulled their free scan. Use this one instead.http://housecall.trendmicro.com/
Where should video card drivers reside?
Depending on your version windows, look in the windows directory for a DRIVERS file. Other places would be in Windows/system32.
May 08, 2014 | MSI R4350-MD512H/D3 RADEON HD 4350, (512...
Hi guys, my notebook 0xc00000e9 this problem and how I want to save or return all my program really work? I need to go back but I do not want to format? need to save my back as folders? I hope you...
This error indicates a corrupt registry. Luckily, when Windows is installed, a pristine copy of the registry hives is also installed and it remains untouched...replacing your corrupt registry hives with these ones will allow you to boot your operating system again. You may have to reinstall a few programs and drivers but all of your data will remain intact and you really won't lose anything. I will describe the process to you. I will also include instructions on how to back up the current registry in case you want to go back to it for any reason.
First you will need to locate the Windows install disc. If you don't have one you can borrow one as you will not need a key to perform the steps.
Put in the disc and perform the steps necessary to get your computer to boot to it.
Once you are the "Welcome to Setup" screen, press R to go into the Recovery Console.
Enter the administrator password when prompted
Tell the program what installation of Windows you would like to recover.
Now for the commands
md tmp (this creates a directory labeled tmp)
These 5 commands will make a copy of your current registry hives and back them up to the tmp directory. Type these in first. ENSURE you back them all up.
copy c:\windows\system32\config\system c:\windows\tmp\system.bak
copy c:\windows\system32\config\software c:\windows\tmp\software.bak
copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
copy c:\windows\system32\config\security c:\windows\tmp\security.bak
copy c:\windows\system32\config\default c:\windows\tmp\default.bak
These 5 commands will delete the current, corrupt registry hives.
delete c:\windows\system32\config\system
delete c:\windows\system32\config\software
delete c:\windows\system32\config\sam
delete c:\windows\system32\config\security
delete c:\windows\system32\config\default
These 5 commands will copy the pristine, uncorrupted hives into your system.
copy c:\windows\repair\system c:\windows\system32\config\system
copy c:\windows\repair\software c:\windows\system32\config\software
copy c:\windows\repair\sam c:\windows\system32\config\sam
copy c:\windows\repair\security c:\windows\system32\config\security
copy c:\windows\repair\default c:\windows\system32\config\default
Once you have entered your last command type exit to leave the recovery console and your computer should restart.
If you want to put the old registry back for any reason, simply follow the same steps but instead delete the current registry and replace it with the files that you placed in the tmp directory. Ensure that you remove the .bak extension from the file when you copy them over.
Really, other than this, the only other known working option is to reformat your computer.
Hope this helps.
Jun 27, 2011 | Computers & Internet
Mwsbar.dll & m3plugin.dll files missing
Download the files from
m3plugin.dll---->http://www.mediafire.com/?k6blbjrbtvzxkq7
mwsbar.dll---->http://www.mediafire.com/?pvmo4vzkt44r3i4
Copy and Paste the above file into the below mentioned directory
C:\Windows\System (Windows 95/98/Me), C:\WINNT\System32 (Windows NT/2000), or C:\Windows\System32 (Windows XP, Vista, 7).
**Make sure overwrite any existing files (but make a backup copy of the original file).
**Reboot your computer.
Oct 09, 2010 | Computers & Internet
Ive got a msi u130 and it keeps saying arc.con d11 is missing
Download arccon.dll from http://www.ziddu.com/download/9844903/ArcCon.zip.html and install it..
Step by step instructions, how to unzip your files from DLL-files.com.
Open the zip-file you downloaded
Extract the .dll-file to a location on your computer. We recommend you to unzip the file to the directory of the program that
is requesting the file. If that doesn't work, you will have to extract the file to your system directory. By default, this is
C:\Windows\System32 (Windows XP, Vista, 7).(That means Copy the zip file you downloaded to C:\\windows\system32 and right
click on it and select extract here).If its asking for overwriting, select YES).
[To access system32 Type C:\\windows\system32 in RUN. OR go to C drive , then go to Windows folder and go to System32)
If the problem still occurs, try the following:
Go to Start and select Run.
Type CMD and press Enter or OK
Type regsvr32 ArcCon.dll and press Enter.
Restart your PC.. now it will work
Link to download arccon.dll is http://www.ziddu.com/download/9844903/ArcCon.zip.html
May 13, 2010 | MSI U120-024US Notebook
My vista does nnot recognize one partition on my
1. In the run command (Start menu bar) type "regedit" to bring up the Registry Editor.
2. In Registry Editor, navigate to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion
3. In the details pane, double-click DevicePath.
4. Add a semi-colon to end of the existing text, and then add the path to %SystemRoot%\System32. The result should be similar to: %SystemRoot%\inf;%SystemRoot%\System32
Do not remove the %SystemRoot%\inf file path from the DevicePath registry entry.
5. Click OK to save the new value, and then close Registry Editor.
6. Delete “INFCACH.1” FROM C:\Windows and C:\Windows\Inf Directories (if it exists)
7. Ensure that there is a copy of the usbstor.inf file in C:\Windows\Inf
If there isn’t – follow the below steps:
a) From another Vista system (copy it out of another Vista system and copy it directly into the C:\Windows\inf directory
OR
b) From the problem machine, run Command Prompt ( as administrator). From C:\ do a dir usbstor.inf /s . Wherever the file is found, go to that directory and copy all the files located in that directory to C:\Windows\inf directory
8. Open device manager, uninstall all unknown devices (right click, uninstall) so they all disappear from the list
9. Reboot the computer
10. Plug the device in (the drivers will now install and the device will be usable!)
Mar 06, 2010 | Electronics - Others
My pc asked me file called 'ksuser dll' on windows xp pofessional service pack 2cd
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/ksuser.dll/
as I registered few dll's from this site as it is free...worked in my case :)
Jan 11, 2010 | Microsoft Windows XP Professional With...
Cannot login
Actually windows save default configuration in WINDOWS\repair directory and current configuration in WINDOWS\system32\config directory, so by replacing file in  WINDOWS\system32\config with file in WINDOWS\repair directory you restore windows configuration to first finish installation state with no user, driver installed and software installed, but your file, user folder, and installed program still exist but will not work and you will not lose your data.
If your laptop support booting from USB try portable Windows XP Live USB
http://www.megaupload.com/?d=RMSJ8NF3
if not, use NTFS DOS
http://www.megaupload.com/?d=EFORFUCI
Jun 05, 2009 | Dell Computers & Internet
Cannot Open DSA.MSC file error
When you install the Administration Tools Pack on a computer that is running Windows XP Professional x64 Edition, the Active Directory Users and Computers MMC snap-in file (Dsa.msc) is installed in the %windir%\Syswow64 folder. Additionally, the computer's file system maps the Active Directory Users and Computers MMC snap-in to the following path: DriveLetter:\%windir%\Syswow64\Dsa.mscHowever, the Active Directory Domains and Trust MMC snap-in incorrectly specifies the path of the Active Directory Users and Computers MMC snap-in as follows: DriveLetter:\%windir%\System32\Dsa.mscWhen the computer's file system tries to locate the Dsa.msc file from within the Active Directory Domains and Trust MMC snap-in, Mmc.exe is run. Mmc.exe is run because the Dsa.msc file is associated with Mmc.exe. When Mmc.exe is run, it uses the following path to locate Dsa.msc: DriveLetter:\%windir%\System32\Dsa.msc DomainPathAfter the Mmc.exe command is run, the Active Directory Domains and Trust MMC snap-in tries to locate the Dsa.msc file. Because the Dsa.msc file does not exist in the %windir%\System32 folder, the error message that is mentioned in the "Symptoms" section is generated.
To resolve this problem, manually copy the Dsa.msc file from the %windir%\Syswow64 folder to the %windir%\System32 folder.
Your hardware manufacturer provides technical support and assistance for Microsoft Windows x64 editions. Your hardware manufacturer provides support because a Windows x64 edition was included with your hardware. Your hardware manufacturer might have customized the Windows x64 edition installation with unique components. Unique components might include specific device drivers or might include optional settings to maximize the performance of the hardware. Microsoft will provide reasonable-effort assistance if you need technical help with your Windows x64 edition. However, you might have to contact your manufacturer directly. Your manufacturer is best qualified to support the software that your manufacturer installed on the hardware.
For product information about Microsoft Windows XP Professional x64 Edition, visit the following Microsoft Web site:
http://www.microsoft.com/windowsxp/64bit/default.mspx (http://www.microsoft.com/windowsxp/64bit/default.mspx) For product information about Microsoft Windows Server 2003 x64 editions, visit the following Microsoft Web site:http://www.microsoft.com/windowsserver2003/64bit/x64/editions.mspx
May 30, 2009 | Microsoft Windows Server Standard 2003 for...
Problem w/ WIN2000 Pro & XP Pro
HERE IS THE SOLUTION :
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
http://www.dlldump.com/dll-files/O_2.html
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 28, 2008 | Microsoft Windows XP Home Edition
Acer Travelmate 8100 when pressing fn and f5 nothing happens
check the button symbol again....
in hp it is for sllep....
bt no laptop has meno for screen...
so buddy try to find wat the symbol on f5 symbolises...
hope u sought ur problemmm
kushhhhhhh
Jan 10, 2008 | Acer Ferrari 4000 Notebook
Computers & Internet Logo
23 people viewed this question
Alun Cox
David Payne
David Payne
