Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 Printer starts the paper feed ok but half thru the paper turns to the right and jams. Cannot open the back panel to location of jam
    Genius:
  • 2,785 Answers
Its seems that your printer have some hardware problem it will be better if you take it for servicing
Posted on Aug 06, 2010
My lexmark x5470 printer is jammed inside and I cant seem to be able to open it in order to get the paper jam out of it. Any suggestions?
You can try the following. Press and hold the check mark untill you hear the printer turning the rollers. That will cause the printer to try to feed a paper sheet. If that does not pulls the jammed paper out then you will probably have to find a way to remove maybe using some long nose pliers.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper jam Lexmark X5470
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Nov 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 printer says, "Clear paper jam, then press check mark."
May 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X4850 paper jam
May 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
X5470 jammed
Paper Jams in the Printer ID:412
Apr 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Newly installed won't stop jamming paper
If this didn't work please replace the printer by the company..
Apr 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
244 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
