Question about Sharp EL-1197PIII Calculator
Can't figure out how to set the tax rate on my el-1197piii> can i please have the instructions to do this. Thank you!
SOURCE: Set Tax Rate
Type in the rate of tax you want to use, then press rate and then press tax+ :)
Posted on Jul 14, 2008
SOURCE: Resetting sales tax rate on Casio HR8TE calculator?
Thanks very much it was very helpfull.
NC- Sri Lanka..
Posted on Jul 22, 2008
SOURCE: how to set the tax rate
Its easy just type in the tax rate that you want, then hit the rate button. Afterwards leave tax+ pressed and you should see the tax % sign appear above the number you punched in, and THATS IT!!! Easy!!!
Posted on Jul 23, 2008
SOURCE: SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Posted on Apr 10, 2009
How do i change the tax increase rate on my sharp EL-1197pIII
Move 'GT' '.' 'RATE SET' selector to 'RATE SET'
Tax / discount rate: • Press the TOTAL key twice, enter the tax rate, followed by the TAX+ key. •
Press the TOTAL key twice, enter the discount rate, followed by then TAX- key • A maximum of 4 digits can be stored (decimal point is not counted as a digit). Note: • Be sure to set above noted selector to the "•" position after storing an each rate. • For the conversion rate and the tax / discount rate, a single value can be stored for each. If you enter a new rate, the previous rate will be clear
May 27, 2016 | Sharp El1197P111 Printing Calculator
Need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
How do you set the tax rate
Example: setting 5% tax rate
1. move mode switch to 'rate set '
2. press 5 (for tax rate ) followed by TAX+ button
3. Move mode switch to GT
to add tax to e.g 200 type:
200 TAX+, the result is 210
Feb 16, 2009 | Sharp EL-1197PII Calculator
Setting tax %
It is glorious!!!
Dec 18, 2008 | Sharp EL-1701C Calculator
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
RATE SET(+TAX Key)
CA
C.CE
C.CE
May 01, 2008 | Sharp EL-330AB Calculator
Set tax
To set your tax rate:
1. Be sure to switch to "rate set" from GT
2. Enter the tax amount like so - if your tax rate is 7% type in 7%
3. Go back to the GT setting and it should work...at least that is how I fixed mine! I did the same thing last week & have no manual!
Hope this helps you
Mar 03, 2008 | Sharp EL-2196BL Calculator
It is glorious!!!
Jan 20, 2008 | Sharp EL-1701C Calculator
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
Setting tax
try switching the top button next to GT to rate,then enter your tax rate then % (8.25%) then switch the top button back to on (or whereever you had it set to) and hit the tax+ button. That worked for me. GO TEXAS!!!
Sep 29, 2007 | Sharp EL-2630P Calculator
Sharp EL-1197PIII Calculator Logo
205 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
