Question about Kitchen Ranges
Maytag Gemini, gas stove top striker is stuck on? how do I fix?
SOURCE: Maytag Gemini gas top oven does not work.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerry rigging a bridge to wire the BAKE igniter to the BROILER controls. (Push/click plugs accessible by opening up the stove back) Testing the broiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.) The parts and wiring are pretty simple and visual once you get the covers off. Opening up the stove back is just a matter of removing several screws. UNPLUG the stove before you work. If you test as I described, make all connections while UNPLUGGED and then plug it in only for the brief test. Unplug again while disconnecting/reconnecting. Hope this helps.
Posted on Dec 04, 2008
SOURCE: Maytag gemini gas stove. Ignitor problems
My experience with this is that it occurs when moisture gets into the ignitor area and shorts out the open and causes the spark. It stops after it drys out.
This is very non-techinical and I will defer if there is a deeper solution.
Posted on Jun 11, 2009
Greg20
  • 149 Answers
SOURCE: ge profile stove top strikers stuck on
If water or liquid gets in the switch it can short the circuit and cause the igniters to fire.....try pulling the knobs off and hairdrying the switches..i had one that sparked for 2 days before they finally stopped. good luck :)
Posted on Jun 15, 2009
garing
  • 998 Answers
SOURCE: lower element of top oven does not heat on Maytag Gemini
replace the control
Posted on Aug 06, 2009
woodchuck789
  • 4070 Answers
SOURCE: maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
Posted on Sep 18, 2009
I cannot relight my stove after a power outage? I have a gemini maytag
Could you please describe the problem you are having a little better?
Is it the stove, the top burners or everything?
Nov 30, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag Gemini gas stove top ... while starting one of the front burners, the starter knob in the back started on fire. Help!!
You have a gas leak which resulted in the unwanted fire. This has the potential to be serious or deadly. This is one time when you need to get a pro in there to stop this leak and get your stove safe again.
Jun 16, 2009 | Maytag MGR6775A Gas Kitchen Range
Maytag MGR575qdq gas oven
Replace thermostat in oven and this should fix ya!
(Please rate answer to help keep this site FREE!)
Thank You!
Dec 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
How do i clean the top of my gemini stove
Use Baking Soda and water and form a paste. Use this to clean the top of your stove. If food is really baked on, you might also consider using a single blade razor to scrape the mess off. Rinse well.
Sep 21, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Top of Gemini range
Hello patricialc,
Welcome,
You said, you have the stainless Gemini range and the top is black. I cannot get the top clean. It looks like the paint or the surface is "bubbled". I have tried EVERYTHING and it always looks like there is grease spatters on the top. I have all Maytag appliances and I am VERY disappointed with this stove. If I could, I would take it back...but I keep trying. I let the Maytag stove I had go. It was made in the late '50's, so I could 'update'. What a mistake!!!
The other option is to order a new glass top and have it replaced.
No abrasives!!
Let me know how you do.
Huuum
Please remember to leave a rating!
Jun 29, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag gemini gas oven
you have to allow the broiler to warm up. give it a few minutes (maybe even ten) eventually the broiler will come on.
Nov 12, 2007 | Maytag MER6772 Gemini Electric Kitchen...
on the oval window of my gas stove, maytag it says 5 Ab my oven won't work because of this
Oct 29, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
121 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
