Question about D-Link DI 514 Wireless Router (DI-514)
I'm having an issue with my DI-514 wireless router. I can connect fine when the router first boots up. My laptop will stay connected to the router all day. The problem happens when I disconnect from the router and try to reconnect again. Whether the laptop goes to sleep, I shutdown, or manually disconnect the wireless connection, I cannot reconnect until I power cycle the router.
  • teepspalmer Aug 06, 2010
    Adjusting the power save didn't help. It wasn't a problem with the lappy turning off the laptop's wifi device. It will stay connected as long as I don't disconnect it. The problem comes with when I do disconnect, I can't reconnect until I power cycle the router.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 159 Answers
Open Device Manager. In the Device Manager window, click the plus (+ ) sign next to Network adapters to expand the selection. Under Network adapters , click to select the appropriate wireless LAN adapter. On the menu bar, click Action and then click Properties . In the Properties window, click the Power Management tab. On the Power Management tab, click to uncheck the box next to Allow the computer to turn off this device to save power . Some WLAN adapters have another power saving setting in addition to the one on the Power Management tab. Click the Advanced tab and try to locate a power saving setting. If it exists, disabled it. Click the OK button.
Posted on Aug 06, 2010
The internet is working on my computer that has a cable running through the router. However, I can't get any networks on my laptop. I've tried turning the router off and back on. Any advice?
First of all check your network connection setting for IPV4 Properties, if there is any IP in it, just remove it and try. also if you trying to connect it with wireless network, just change the security and authentication type to a different format. I hope it will work fine. Please let me know the result.
For more assistance, please stay connected with us.
Thanks for joining us. Have a nice day.
Feb 21, 2011 | D-Link DI 514 Wireless Router (DI-514)
Cant'tget on remote wifie from laptop outsie home
Hello there.
So theres no connection? Like how far are you from that router? I suggest dont go to far on the router. Stay in below 100meters for better connection.
Hope this helps and please rate.
Sep 24, 2010 | D-Link DI 514 Wireless Router (DI-514)
Have internet on main PC but cannot get connection for laptop Using D-Link 514
Is this a wireless connection? Make certain the router is transmit is turn ON and on high power. Make certain your laptop WiFi is turned on. Use the network connection to connector to the router.
Jul 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
I can get on the internet if I connect directly from my cable modem to my desktop, but not if I connect through my dlink di-512 ethernet port, however the wireless works ok on my laptop with the same...
1. check the status lights on the router if they flashing you have lost connectivity.
2.unplug or press the reset button on the back of the router hold in. this will reset the router
3. reboot the PC. this will reset the PC.
4.when connected you will have to update the firmware.
I looked at the manufacturer's site and this router is discontinued but there are resources to troubleshoot this issue
http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
go to this page above to do further troubleshooting.
Feb 20, 2010 | D-Link DI 514 Wireless Router (DI-514)
D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like 192.168.0.2
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
Dec 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Short connection and then no connection
This is a problem with the firmware of the router, so the best way to resolve this is to flash or update the firmware of this router then after that reset the router by pressing the reset button for about 15 seconds so the firmware update will take effect....
Nov 12, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI 514 Wireless Router Problem
you upgrade new version firmware in your wireless router
Apr 02, 2008 | D-Link DI 514 Wireless Router (DI-514)
How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at http://192.168.0.1) and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Feb 10, 2008 | D-Link DI 514 Wireless Router (DI-514)
Connection Issue ~ D-Link DI 514
Connect to your router, then on the computer click start/run, type CMD at the >, type ipconfig /release, then ipconfig /renew this will reset all ip address from your computer through your router to your modem. this should fix the problem. BPCS
Dec 30, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514 Wireless Router (DI-514) Logo
114 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
