Question about Refrigerators
Walk in freezer door heater is not working? - Refrigerators
I have a walkin freezer by Amerikooler Inc., the freezer door is freezing up because the door heater is not working. How can I fix this problem myself?
Posted on Dec 01, 2008
  • 81 Answers
Hi from The Gasket Guy, Inc.
I am Jeff Weisman and I can have someone come to you and give you a free estimate on the repair/replacement of your door heater. The price range for replacement (most likely solution) is from $189 to $299 depending on size and type of freezer. Amerikooler is usually toward the lower end of the price range, providing it is a standard freezer (-5 deg - +10) with an opening of less than 36X78.
Call me immediately at 561-889-3600 and I will have your problem solved in a "jiffy".
Posted on Apr 23, 2009
Kolpak walk in freezer . the door heater will not work
Suggest replace the element.
Since this is an electrical/safety issue also suggest have qualified personnel attend to it.
Nov 02, 2017 | Kolpak Refrigerators
Freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Oct 27, 2007 | GE GSS20IEM Side by Side Refrigerator
External unit on my walk-in cooler will not shut off. Seems to be due to the Ranco Pressure Sensor. How do I fix or adjust?
Diagnosing Walk-in Coolers & Freezers Problems
blog.uscooler.com/walk-in-cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
Maintaining & Cleaning Your Walk-in Cooler or Freezer
blog.uscooler.com/maintain-walk-in-cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
[PDF]INSTALLATION & SERVICE MANUAL - Polar Leasing
Dec 10, 2015 | Refrigerators
My lfx25960sb lg refridgerator won't defrost it builds ice on the coils the heater looks ok
Looks cannot always tell if there is a problem with the defrost heater or defrost thermostat. Your model uses the=> 5300JK1005D Defrost Heater Assembly and the=> 6615JB2005H Defrost Sensor Unplug before working on your fridge. Can you find an ohm meter and remove he rear panel in the back of the freezer? I can walk you through this if to lie. Also tellme what type of frost pattern you see once the rear panel inside the freezer is removed. Completely frosted over? Half or less frosted over? Clump or ball of ice where the small tube enters the large copper tube on the evaporator? Just ask questions on your post here on Fixya I am here to help, Thanks, John Tripp Appliance 911
Jan 31, 2014 | LG LFX25960 Bottom Freezer French Door...
The Refrigerator side is warm, and the freezer side is not making enough ice,and the ice is not solid
Possibly the defrost heater could be faulty or the defrost thermostat or defrost thermistor (sometimes called D-Sensors I believe). If you turn off the fridge and let it defrost itself for 12 hours and then start it again, it may work fine for a week or two (or may even be totally fine in case you left the fridge or freezer door open by accident).
Oct 05, 2012 | Nor-Lake Norlake Refrigeration 4' x 6'...
Commercial walk in freezer door damaged needs repair or replace?
I Need two panels replaced on my Walkin Cooler, is there anyone that cacn give me a quote/price for this repair
Nov 14, 2009 | Freezers
Nor-Lake t3000 freezer - door HOT
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Mar 27, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Replacement door seal for walk in freezer
First, call Restaurant Parts and More (1-888-814-1110) and ask for Rick. He can help either get you the seal or have one custom made. I've used him for 15 years with great success. If you have model and serial, it would be even greater.
He can do the same for the heaters that go around the door frame.
Don't understand which "Line" you are referring to. In alot of cases, the drain on the drain pan is clogged. This causes water to overflow onto the floor. The drain can be clogged from trash getting into it. Most of the time, the drain heater is either not working or not ever installed. Water refreezes in drain line and causes the overflowing problem.
If this does not help, let me know. Clear up the "Line "question and maybe I can go alittle deeper into this.
Aug 16, 2008 | Freezers
Refrigerator
It may well be the defrost control. They have a turn slot to advance them if the timer quits. You need a little aptitude to find this and check it. If you think you can do it let me know, and I will walk you through it.
Dec 16, 2007 | LG LFC25760 French Door Refrigerator
Norlake walk in fridge
Yes if the evaporator drain is blocked or not attached correctly it causes the humidity to remain in the refridgerator. Just opening the door will cause the warm are to enter and cause the symtoms of rain if the water is not taken out the drain properly.Hope this helps JT
Oct 15, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Refrigerators Logo
1,807 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
