Question about Canon NP 6551 Black and White Copier
We got an error message E020 and it says to turn the machine on and off again. We did and it didn't go away. Is there anything else we can do?
    Problem Solver:
  • 5 Answers
Toner Concentration sensor is faulty
Posted on Aug 08, 2010
  • tripsdad544 Nov 18, 2010
    Actually it is probably just dirty. Take the two out and clean them then turn the machine on again and it will likely go away. The two sensors are at 2 o'clock and 4 o'clock around the photoreceptor belt.
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
E020 01BO What does this error code mean?
E020 indicates a Black Toner malfunction. If you've recently changed the toner and failed to distribute the toner by gently shaking it from side to side, this could be the cause of this error or if the toner is very low it could trigger the same error.
01B0 is a drum error related to your toner error message. If toner cartridge is good, remove the cartridge, clean the drum, replace the cartridge and both errors should clear. A dirty drum will also trigger your 1st error e020.
Nov 16, 2009 | Canon CLC 1120 Color Copier
I have an older Canon clc 900 Error E020 Switch power on and off again"displays when trying to copy. When I turn the copyer off and on again the same message displays.What to do ?
Error :
Intermittent E020 / E061 codes.
Workaround :
It's possible that there is a poor drum ground from the static eliminator brush. You may need to replace the static brush with the drum grounding leaf spring from a CLC 350 (part numberFA5-9308-000). Follow the procedure in technical publication CTP.NO 700/800-69.
Error :
E020 sub code 0440 and light density on all colors
Workaround :
Check the developer assembly movement, i.e. up & down and that the magnetic roller is turning. Check the EPC readings, laser output, fold back mirror, and the connectors for the developer and the developer bias contacts. If all the above checks are good, then the problem can be with the AC voltage output of the developer bias HVT. The DC-voltage for the developer bias is split between two colors ( magenta & yellow ) or ( cyan & black ). The AC voltage is supplied for all four colors and it's loss will be seen in all the colors whereas the loss of the DC voltage would affect only two colors. To fix the problem replace the developer bias HVT part # FG5-3068-060.
Oct 18, 2009 | Canon CLC 1150 Color Copier
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
E020 Error message on NP6050
A E020 code is a toner amount problem in the developing ass'y. Is the copier asking for toner or was it and no toner was installed? If not the amount of toner is to low for the hopper to add enough toner in to over ride the toner sensor. Look in the developing ass'y for toner, if you only see about a 1/8' of toner you need to clean or replace the toner sensor. Then you are going to have to run in service mode " toner-s". Then rechk the amount of toner in the developer ass'y. It should be about a 1/2' or so. If not you have a problem with the toner hopper. And if that is the problem you may want to manually add toner in the developing ass'y to get the copier working again. You also have to clear the error code in service mode.
Jan 28, 2008 | Canon CLC 1120 Color Copier
Error e020
The developer unit is looking for toner from the hopper. E020 can also be the DC Controller or the developer unit itself. The toner cartridge is probably fine. This can be complicated to fix. The copier is probably still under warranty. It's better to call up Canon 1-800-828-4040 and have them send out a Certified Technician to fix this. Sorry I couldn't help more. Ray
Jun 20, 2007 | Canon NP 6545 Copier
Canon NP 6551 Black and White Copier Logo
old marine
old marine
