Question about ASUS Eee PC 2G Surf Notebook
My mini notebook will not boot and tells me it can not locate windows because of a dll error
  • ASUS Master
  • 12,061 Answers
Http://support.microsoft.com/kb/308041
Try this at the above website..
http://lionpress.wordpress.com/2008/04/26/eeepc-how-to-restore-to-factory-settings/
Or try below...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, then replace that faulty DLL, or better still, do a System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Master link below. EEEPC restore link
http://www.google.co.nz/search?num=100&hl=en&q=asus+eee+pc+factory+restore&aq=1c&aqi=g1g-c6&aql=&oq=asus+factory+restore&gs_rfai=
Posted on Aug 06, 2010
Hw to remove run DLL error in microsoft window 8.1
run.dll is a DATA LINK LIBRARY FILE if it is sikped in installing windows {or} other any software ,malware,adware virus problem you can fix it by using DLL suite { the dll suite download and install it will have a lot of serials keys in serial.ws.com } you will enjoy the features of windows
Apr 06, 2015 | Microsoft Computers & Internet
Msvcrt.dll error message(Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
Two possible solutions.
Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 23, 2012 | Microsoft Windows XP Professional
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
On screen message telling me windows could not start because the following file is missing or corrupt- <windows root>\system32\hal.dll. Laptop does not start or boot properly
Time to get out that restore disc you made when you first got your laptop. The boot sector has errors. Boot with your rescue disc and run CHKDSK/F to clear the errors.
Hope that helps.
Feb 16, 2011 | ASUS Eee PC 701SD 8G Notebook
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Won't boot/reboot after turning off yesterday
1. boot from a Windows CD and go for the repair option.
2. Copy usp10.dll from c:\windows\servicepackfiles\i386\gdi32.dll to c:\windows\system32\usp10.dll. (Do keep a backup copy of the old usp10.dll in c:\windows\system32 directory )
3. Reboot normally
http://www.aa1consulting.com
Jul 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
ASUS Eee PC 2G Surf Notebook Logo
196 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
