Question about Amana ARB1905C Bottom Freezer Refrigerator
Referigerator isn't cooling at high settings - Amana ARB1905C Bottom Freezer Refrigerator
  • Amana Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerreferigerator isn't cooling at high settings - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 06, 2010
Why is the refrigerator not cold, but cool?
If freezer is working & refri.not check damper vent could be frozen or closed
May 07, 2015 | Refrigerators
Why is there frost inside my referigerator?
It may be set too high {cooling #} or the back where the refrigeration fins are need to be cleaned. On some models there is a metal plate hiding the fins you have to remove it then vacuum out the back to remove dust and debris. try adjusting both the freezer and refrigarator settings
Sep 05, 2013 | Refrigerators
MY REFERIGERATOR TURNS ON BUT DOESN'T COOL
if it is a fros free check fan in the frezzer that is what cools the frige
Sep 12, 2012 | Danby DFF9102W Mid-Size Refrigerator White
Roper referigerator not cooling (ice bound) model RT14HDXDW03C
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 12, 2011 | Refrigerators
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
I have a Ropper Referigerator model # RT18bkxkoo. I am facing following issues: 1. The freezer section is working but I have noticed some ice developed at the back wall. 2. The referigerator section...
were
werw
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
dfg
Dec 27, 2010 | Roper Refrigerators
Referigerator is not getting very cold and the freezer is frosting
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 21, 2010 | Whirlpool ET0WSRXML Top Freezer...
Not cooling well.low cooling
If it is working but not cooling as it should, it is probably in need of coolant. This is not a job for the home owner. Special tools and equipment are required along with the compressed gas. Call a white ware repair facility.
Jim Hart
Jun 20, 2010 | Refrigerators
Ice is building up on the back cooling panal in frost free referi
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Refrigerators
Kitchen Aid side by side referigerator KSSC42QMSO
the freezer does all the cooling for both sides a few shelves down in the fridge on the left hand side there is an air intake make sure nothing is blocking it also listen for the freezer fan to run if its not look at the coils in the bottom of the freezer to see if they are heavly frosted in the fridge side at the top left side should be some vents hold your hand there to see if air is blowing through if not reply to me well go from there
Nov 29, 2007 | KitchenAid KSRP22FNSS Side by Side...
Amana ARB1905C Bottom Freezer Refrigerator Logo
48 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
