The printer is not picking up the paper from the tray. As best as I can tell anyway.
  • 64 Answers
The pickup roller could be dusty (paper dust) Clean the roller with a damp cotton bud, or buy replacement roller if it still will not pickup.
One other thing to check is see if a paper jam has been removed but torn a bit of paper off, this could be stopping the paper feed path
Posted on Aug 06, 2010
OfficeJet Pro 8600 will not pick up glossy photo paper from the tray
I tried everything that was suggested on the HP forum but then tried something not reccommended there and it worked. Not only remove tray 2 from the printer properties but force the print to tray 2, when you this it sets the Quality from normal or Best to Custom. Once I done that it worked... Just disabling the tray 2 is not enough.
Mar 26, 2012 | HP OfficeJet Pro K8600 Printer
Will not pick up paper from normal tray 1 but does pick up paper from larger paper tray 2 despite having error message that tray 1 is empty, it also has a duplexer fitted. If you put paper in tray1 it...
check the tray one paper empty senor blow out with air is the paper acturator broken that the device that would lay on the paper when its out of paper the sensor will drop far enough to tell the printer tray one is out of paper miss feed are the rollers are dirty and or need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 14, 2018 | Konica Minolta magicolor 2490MF Laser...
When i feed the lexmark x4650 printer with paper,it tells me no paper and it does not pick paper.what should i do?
hello
first check the tray might be the paper is not placed properly, and check the roller pickup of the paper placed upside of the tray, might be the tray is not pushing up the paper to the roler thats why not your printer not picking up paper. try hard reset remove the power cable from the power outlet and at the back of the printer take 5 minutes to plug in back.
inform me then...
thank you
Mar 05, 2011 | Lexmark Office Equipment & Supplies
My printer, HP injet 1410, could not pick up the paper. Can you tell me what the problem is.
I assume the printer is making noises and moving, TRYING to pick up the paper...
If so, there are 3 possible issues:
1) you have too liittle paper in the paper tray. Add more paper so that the tray is full to around 3/4, not less.
2) You may have too much paper on the tray. Remove some paper from the tray untill the tray is around 3/4 full, not more
3) The rubber rolls that pick up the paper may be dirty with paper dust or dirt. Put 2 drops of alcohol on q-tip and carefully clean them. Let dry 30 mins. before trying to use the printer.
Mar 26, 2010 | HP PSC 1410 All-In-One InkJet Printer
Cant pick up paper
the dock will not pick up paper lost my manual i tried one piece half full tray and afull tray it worked last time i printed what up
it keeps saing its out of paper
Jan 19, 2010 | Kodak EASYSHARE G610 Thermal Printer
My hp printer is telling me that i need to add
Not sure what printer you have but most consumer models don't actually detect paper in the tray. These machines will give an out of paper error if the paper is not picked up from the tray.
If the machine sounds like it is trying to pick up the paper but giving the error check and clean the pick up roller and look for something blocking the paper path.
hope this helps
Mar 15, 2009 | HP Office Equipment & Supplies
Paper jam and now printer wont work since all paper has been cleared out of printer
paper pick-up rollers may be warn out.replace rollers.tell me the company &model no.
Aug 04, 2008 | Office Equipment & Supplies
Epson AcuLaser C900 Printer
Error Code 6001 ~ 6999 are simply service required errors and are very general. I would imagine that if the tray is missing the printer will produce a fault. For starters it will think it has no paper and therefore will not try to pick up paper from the tray. If the tray is opened during operation I believe the printer stops, therefore there must be a sensor for the tray - no tray means sensor is operated. Best guess - fit a tray.
Apr 07, 2007 | Epson AcuLaser C900 Printer
104 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
