Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven won't light. burners work, and the broiler works
  • GE Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Aug 06, 2010
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
heatman101
Mar 30, 2010 | Ovens
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
308 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
