Question about Toshiba 50HP81 50 in. Plasma Television
Toshiba 50hp16 pop than crappy pic
I had it on for about 15-20 min watching/ listening the the morning news. I was getting my coffee ready and heard a pop sound. Didn't think much of it. Than i looked over and was like what the %uck. Shut it down, had to go to work. Turned on when i got home it worked but pic was tweaked. Could see it and hear it, but weird colors here and there. Girlfriend had it on the next morning. Next thing she heard a pop once again and the pic was pretty much like 98% gone, just a flicker of a pic here and there. I checked the internal fuses and they are good. I have the back of the tv off now. Any ideas? I am pretty handy, would love some input. Thanks for any help....Jay
  • 1 more comment
  • Captain Spaulding
    Captain Spaulding Apr 29, 2008
    what is or who is ysus and zsus?
  • Captain Spaulding
    it is a plasma. I dont think they have bulbs. If they do than i dont know where. I have the back of the tv off and dont even see where one could be.
  • Captain Spaulding
    Why did you send me all this? It dosent help at all, and has nothing to do with my problem.
    Genius:
  • 1,447 Answers
Might be the bulbs.. try replacing it, or call toshiba support line/ service line.
Posted on Apr 29, 2008
  • Toshiba Master
  • 19,396 Answers
Check ysus and zsus they can blow this way , if it was power board was gone alltogether
    Genius:
  • 1,142 Answers
YOU HAVE TO CALL THE SERVICE TECHNICIAN
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha Apr 29, 2008
    check for troubleshooting in the service manual
    http://www.tacp.toshiba.com/tacpassets-i...
  • Maanita Chadha
    Auto power off
    The TV will automatically turn off after approximately 15 minutes if it is tuned to a vacant channel or a station that completes its
    broadcast for the day and stops broadcasting on that channel. This feature does not work in video input mode.
    Understanding the Power Return feature
    If the power is cut off while you are viewing the TV and the power is resupplied, the Power Return feature will turn the TV
    on automatically.
    If the power is going to be off for a long time or you are going to be away from the TV for a long time, unplug the power
    cord from the wall outlet to prevent the TV from turning on in your absence.
    Symptom Solution
    Black box on screen • Select OFF in the Closed Caption menu to turn off the Closed Caption
    Text mode.
    TV will not turn on • Make sure the power cord is plugged in, then press POWER.
    • The remote control batteries may be dead. Replace the batteries.
    No picture, no sound • Check the antenna/cable connections.
    No sound, picture OK • The sound may be muted. Press VOLUME.
    • The station may have broadcast difficulties. Try another channel.
    • The MTS feature may be in SAP mode. Select STR or MONO in the
    MTS menu.
    Poor sound, picture OK • The station may have broadcast difficulties. Try another channel.
    MTS menu.
    Poor picture, sound OK • Check the antenna connections.
    • Adjust the PICTURE menu.
  • Maanita Chadha
    Picture and sound are out of sync • As with all products that contain a digital display, in rare instances,
    when viewing certain content (e.g., television broadcasts, video
    games, DVDs), you may notice that the sound and picture are slightly
    out of sync. This phenomenon can be caused by various factors
    including, without limitation, video processing within the TV, video
    processing in an attached gaming system, and video processing/
    different compression rates used by broadcasters in their programming.
    You may want to try one or more of the following suggestions,
    which may help to reduce the effect of this phenomenon:
    – If the TV is connected to an A/V receiver that has a programmable
    audio delay feature, use this feature to help synchronize the sound
    to the picture.
    – If you notice this phenomenon only on certain TV channels, please
    contact your local broadcast, cable, or satellite provider to inform
    them of this issue.
    Poor reception of broadcast channels • The station may have broadcast difficulties. Try another channel.
    • If you are using a video input, make sure the INPUT button is set
    correctly.
    Cannot receive above channel 13 • Make sure the TV/CABLE feature in the SETUP menu is set to
    “CABLE.”
    3X80501A_En_p46-bc 46 3/7/06, 3:52 PM
    Introduction Connecting your TV Setting up your TV Using the TV’s Features Appendix
  • Maanita Chadha
    Symptom Solution
    Unable to select a certain channel • The channel may be blocked by the V-Chip feature or CH LOCK
    feature, or erased with the add/erase feature.
    Cannot access signal input sources (VIDEO-1, • Check the VIDEO LOCK feature.
    VIDEO-2, VIDEO-3, ColorStream HD-1,
    ColorStream HD-2, HDMI-1, HDMI-2 and PC)
    and/or Channels 3 and 4
    Multiple images • The station may have broadcast difficulties. Try another channel.
    • Use a highly directional outdoor antenna.
    Poor color or no color • The station may have broadcast difficulties. Try another channel.
    • Adjust the TINT and/or COLOR in the PICTURE menu.
    No stereo or SAP sound from a • Make sure the MTS feature (in the AUDIO menu) is set properly.
    known MTS broadcast
    The V-Chip password does not work • Change or reset your password.
    (U.S. V-Chip system only)
    The remote control does not operate • Make sure the TV • CBL/SAT • VCR • DVD mode is set properly on the
    remote control.
    • Remove all obstructions between the remote control and the TV.
    The side panel buttons do not operate • Check the PANEL LOCK feature.
    Digital broadcasting screen problem • Check the digital signal strength.
    Closed Caption box appears with no text • Make sure the Closed Caption “Text Color” and “Background Color” are
    not set to the same color
The lyric of this song : you dont know me by the things you heard but you don't l got news for you just help me sing this song why can't we just get along.
Why Can't We Just Get Along?
Written by: R Hughes
Verse 1
You don't know me but you think you do
Because the things you've heard you believe to be true
But I've got news for you
Here's what you need to do (yeah)
(Chorus)
Help me sing this song
Tell me why can't we just get along
Yeah yeah yeah
Yeah yeah yeah
Verse 2
Saw you standing there the other day
But when I greeted you, you looked the other way.
Repeat Chorus
Got me mixed up in your innuendo
Cause you said you saw me through your bathroom window
But I was nowhere around
Why you wanna drag me down (Yeah)
Repeat chorus
Won't you listen to me
Tell me won't you try
I can see the anger in your eyes
But I've got something to say
We need more loving today (Yeah)
(Repeat Chorus till end and ad lib)
Apr 28, 2015 | Audio Players & Recorders
Are there toxins in Keurig Coffee makers?
Keurig K-cup pods are sealed and therefore LESS susceptible to outside issues. There is nothing about a Keurig coffee maker that would make it any more susceptible to issues than any other coffee maker.
And what's with the "I have heard"? You sound like Fox News...Facts are NEVER prefaced by "I have heard", "Sources say", "It is being reported", and "People with knowledge are reporting".
Sep 26, 2014 | Keurig B60 Coffee Maker
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Power train, transmission questions.
Get ready for a overhaul. Ask the transmission companies and they will tell you that us Dodge owners are their best customers. Your torque converter is getting toasted. You have about 10k before it goes. Sorry for the news. Got mine done and now at 213, ooo so it was worth 1700 to get it fixed. got an extra 60 k and going strong.
May 15, 2008 | 1995 Dodge Caravan
My Toshiba 50HM66
i suggest checking the lamp. find you owners manual and go through the steps to "replace the lamp" if it is popped and you can see little pieces moving around inside than contact toshiba and they will send you a replacement with credit card numbers of course.
Mar 21, 2008 | Toshiba 50HM66 52" Television
Open Questions:
Toshiba 50HP81 50 in. Plasma Television Logo
280 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
