Question about Logitech Webcam
Driver remove in my pc - Logitech Webcam
Lexmark z611 printer
First you removed old driver and PC restart and some time wait restart PC and Installation before PC full scan and removed it virus if virus available in PC then be be not proper driver installed or many error show, better of virus remove then installed driver. Driver installation after check it ink label if ink shoot then not any print if ink available or not print then open printer cartridge or check it damage you ink cartridge.
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_Z611&page=product&frompage=null#1
Thanks,
Lexmark Printer Support
May 21, 2014 | Apple Computers & Internet
I have tried downloading 2 drivers for Quantum PC Camera QHM 500 LM but nothing is working can i get any software where it automatically detects the drivers and download it ?
Hi! Here's some hint. I presume you are using Windows 7 or higher operating system version. Make sure you are connected to the internet. Detached the pc camera, remove completely the old drivers at Control panel, device manager, camera, so on... Before removing however, please take note if the drivers for the pc camera marked Warning (usually yellow or read exclamation). Now, insert the pc camera again until it is detected when ask to insert cd/dvd driver select online search driver instead let the online intervention do the crawl. Else download the specific driver that matches your pc camera. Take note when installing drivers do not attached the device yet until you are told to do so or when it is finished installing. Try plugging it to other usb ports available. An updated operating system may also solve driver issues. Try also installing the pc camera on other pc-unit with different operating system.
Mar 07, 2014 | Quantum GoVault Cartridge With Docking...
I just formated my pc and the wifi aint working
Please check your driver, there might be possible that you have removed your driver or might be driver not installed.
Please check your driver first if not installed please installed and I believe that your problem will have been removed.
Good Luck
Dec 21, 2012 | Gateway MD2614u Notebook
When I connect my camera to my computer It says cannot find driver.( CANNON 350D DRIVER )
Please open control panel , then program settings and search for any camera driver softwares if they were installed earlier. If so click on them and select remove /uninstall so that the driver is fully removed.
Now try and connect the camera to the PC and is if this wont detect , please check it another PC. Is not .the camera has faults within the main processor panel
Jul 28, 2011 | Computers & Internet
My dvd has vanished from my computer and i don t have any driver how can i install it again?
Remove the side cover of your pc tower. Find the retaining bolts to the DVD player, remove bolts, remove wires., remove DVD player. Shut down and reboot PC - shut down pc - reinstall DVD player it will load the drivers from memory. If it doesn't then replace the DVD player.
Jan 03, 2011 | Computers & Internet
My Acer OrbiCam no longer opens
try removing the driver - then removing the item from your list. Reinstall both the cam and driver. If this still doesn't work. Try the unit on another pc. If it works on another pc - yet still refuses to work on yours. REMOVE the DRIVER then DEFRAG. - After you defrag - remount the unit and add the driver. If it still doesn't work you will need to download CCLEANER - and run that.
Best of it
Gary @ Fix Ya
Dec 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
I can not connect samsung gt 3510 mobile to pc.i hae installed samsung pc suite but while connecting deine system need driver which is not installed...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Delete the driver previously installed by going CONTROL PANEL - ADD REMOVER PROGRAM - click desired driver click REMOVE. For best result RESTART your Computer reinstall the driver. RESTART again your computer you will be done, INSHALLAH.
Oct 09, 2010 | Samsung Computers & Internet
Not recognising reliance netconnect once you disconnect it
may be due to problem with drivers. Remove all drivers of reliance netconnect in add/remove programs. and delete drivers in device manager. restart your system and reinstall drivers
Jun 19, 2010 | Dell Latitude D520 - Celeron Intel Celeron...
How to remove the HP LaserJet 2420n driver from my PC? I no longer use this printer but I cannot delete the driver from my PC which has cost me 18MB of my C hard disk.
Hi..
To remove the installed printer driver on your PC follow this steps. Go to Start / Control Panel / Add Remove Program after that you can see them all installed software. Find the printer driver there which is already installed and remove it. After that the PC will require you to restart the unit to take effect.
Good luck! Thanks for using fixya
Regards
PCmania
Sep 24, 2009 | HP LaserJet 2420dn Printer
No sound
no sound after your remove sound software. try removing hardware sound driver remove sound software. restart system when windows see sound hardware wants to install a driver don't install the sound driver software it install driver and sound package. should fix problem let me if it helped thanks good luck
Mar 21, 2009 | Compaq dc7100 Small Form Factor (PJ361UA)...
Logitech Webcam Logo
16 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
