Question about Sanyo Televison & Video
I purchased a SANYO TV (Model: CM29FS2) two years back. Recently I experienced a fault from this TV. After warming i.e. 30-45 minutes from switching on, a sound (like the one when we turn on/off any switch in the same switch board) is produce from TV speaker. Then the TV restarts automatically. This is heard even when the sound is set to mute. This will not happen if we disconnect video (i.e. by removing video jack). I called authorized service engineers for repairing this fault. They attended and re-soldered all dry soldering. But the fault still continues.
    Top Expert:
  • Sanyo Master
  • 75,756 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 30, 2017
SOURCE: TV Won't Turn On
I purchased the TV using AMX card 18 month ago. They have an extended 1 year warranty on top of manufactory's. I just have this set repaired: replaced SD board, total charge is $550. I already file a claim and hope to get reimbursed soon.
Posted on Mar 06, 2008
mohammed387
  • 1952 Answers
SOURCE: Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Posted on Oct 31, 2008
SOURCE: Samsung 933HD TV - Sound Switches On Automatically
Seems like the auto upgrade in standby mode feature was the culprit.
Switching this off from D MENU>SET-UP>SYSTEM>SOFTWARE UPGRADE did the trick.
BTW my firmware version is T-TMDEUC-1003
Posted on Jan 04, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
Posted on Apr 17, 2010
Sharp LCD TV Takes 20 minutes to warm up
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 12, 2016 | Sharp Televison & Video
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Televison & Video
Does my Sanyo tv have a VGA port? If so, where would it be located?
The ports should be located on the left side back of the set.
Look for the video input RGB.
May 02, 2014 | Sanyo Televison & Video
I purchased a Sony 46 inch TV 2 years ago. I recently experienced a condition where the top half of the screen has horizontal lines through the signal. The bottom half of the screen looks perfect. Also...
the screen driver can make this fault it sit at the back of the screen. if you change that it should work fine after beening replaced. they can over heat.
Sep 22, 2013 | Sony KDL Televison & Video
My new Sanyo HDTV LCD won't come on, although the on light is on.
If your Tv is in warranty or you have a cover plan, you need to return the Tv for repair or replacement.Your Tv sounds like it has a power supply fault.
Feb 28, 2010 | Sanyo DP46849 46 in. HDTV
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Screen adjust?
chec for open bias resistor or leaky capacitor
Jul 29, 2009 | Televison & Video
Tv repair
I have had 3 flat-screens so far, a Polaroid, Panasonic and now a Sanyo. In my experience when this happens, you would remove the back, clean and dust it carefully. If you have never done this before, it is very wise to leave it to the more experienced as the circuit board contains some sensitive parts. The circuit board needs to be looked over for any damage or burn marks. This could reveal the problem. Also, check for blown diodes. They are roughly shaped like a pencil eraser and should be flat on the top. If they are rounded or appear black, they are bad and need to be replaced. Again, if you've never done this, highly recommend leaving it to the more experienced. Hope this helps.
May 22, 2017 | Televison & Video
TV Problem
SANYO MIGHT HELP YOU BUT YOU NEED TO CALL IMMEDIATELY BEFORE MORE DAYS GO ON..
Feb 21, 2008 | Televison & Video
Sanyo tv
cable bos is a scientific atlanta
Mar 18, 2007 | Sanyo PDP-42H2A 42 in. Plasma Television
Televison & Video Logo
61 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
