Question about Accton CheetaHub Classic 2040 Networking Hub
LAN Network, both PC's with static IP's and defaullt and DNS addresses are 192.1683.1.1 tried the other defaults. Both machines connected. when i ping each others IP's request timed out. please help
    Scholar:
  • 55 Answers
Can not really understand what exactly you have done. Please try the following steps:
1. Assign static IP on pc 1 as 192.168.1.2 assign subnet mask as 255.255.255.0. 2. No need to assign default gateway and DNS. 3. Assign static IP on pc 2 as 192.168.1.3 assign subnet mask as 255.255.255.0. 4. No need to assign default gateway and DNS.
Open dos and try to ping. In case if the ping fails then disable all the firewall on both the pc's and try again.
If you are running windows vista then in network and sharing center make sure network discovery and file sharing is enabled.
Regards,
Rashish
Posted on Aug 11, 2010
Tell me how i resolve dns failed connection
ou can try these options. Please follow step by step instructions on your phone.
A. Reset Wi-Fi:
  1. Delete all the configured wireless connections.Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Click on Forget
  3. Do this for all your connections
  4. Now Enable Wi-Fi again. And connect to router.
B. Using Static IP Address:
  1. Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Make sure to disconnect the network if connected.
  3. Now open the network,
  4. Select Static IP
  5. Now you can assign IP Address
  6. Here are default ips (It may vary according to your router)
    IP : 192.168.0.2 or 192.168.1.2
    Subnet Mask : 255.255.255.0
    Default Gateway : 192.168.0.1 or 192.168.1.1
    DNS: any two of these =>
    • 4.2.2.5
    • 4.2.2.1
    • 208.67.222.222
    • 208.67.220.220
    • 8.8.8.8
    • 8.8.4.4
For screenshots visit http://www.samsungbadaapps.com/tips/dns-failed-error-on-wi-fi
Aug 12, 2014 | Samsung Wave 525 Cell Phone
I cant connect my dell laptop nor detect D-Link dlink Wireless N 150 Router through wifi but my mobile devices can and my desktops can also. please help me able to connect in the internet using wireless...
Try assigning your laptop a static IP. To do this in Windows:
  • Open Windows Start menu.
  • Open Control Panel.
  • Classic view: Open Network Connections
    Category view: Select Network and Internet Connections, and thenNetwork Connections.
  • Double-click on your active LAN or Internet connection.
  • Click Properties
  • In the General tab, highlight the Internet Protocol (TCP/IP) item, and clickProperties.
  • In the General tab, click Use the following IP address, and enter: - IP address. The static IP address you want to assign to this computer (try 192.168.1.110 to start). - Subnet mask. Subnet mask used by your router (try 255.255.255.0 to start). - Default gateway. IP address of your router's default gateway (try 192.168.1.1 to start).
  • In Use the following DNS server addresses, enter all the IP addressses for the DNS servers your router uses (or you can try your router's address, probably 192.168.1.1).
  • Click OK.
Source: http://www.hotcomm.com/faq/faq_staticipxp.asp
Please leave feedback for this answer, thanks.
Mar 10, 2011 | D-Link dlinkgo Wireless N 150 Router...
Just install XP PRO sp3 on P4C800 board and current version of 3Com 3C940 onboard LAN. Installation went fine but LAN can not acquired network address and get no or limited connection.Therefore internet...
When your using Internet connection via LAN you need to configure the Internet Protocol (TCP/IP) Properties at the Network Connection Wizard. To configure the Network Connection just follow this steps:
1. Double click the My Computer from your desktop/screen.
2. At the left side of the My Computer menu click the My Network Places then click View Network Connections in the left side of that window also.
3. Double click the Local Area Connection and click Properties.
4. When the Local Area Connection Properties was appear select Internet Protocol (TCP/IP) then click Properties.
5. The Internet Protocol (TCP/IP) Properties are also apear, then click Use the following IP address and fill-up the following: IP Address, Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server.
6. After all you fill-up click OK Button.
Note: Make sure that the IP Address you fill-up in your network connection are not the same with the other computer to avoid conflict. Just copy the configuration on the computer like: Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server. Only the IP Address are unique to the other computer. Example; 192.168.0.5 that is the IP Address of last computer are connected in the network. The IP Address you able to use is 192.168.0.6, only the last digit of the IP Address your going to change.
Jun 04, 2010 | ASUS P4C800 Deluxe Motherboard
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
Can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
Apr 08, 2009 | Zyxel Prestige 660R Router (P660R)
I CAN GET THE INTERNET EXPLORER TO WORK WITH MY MODEM.... SOMEHOW I THINK THE IP AND DNS ADDRESS IS WRONG... IT KEEP SAYING CHECK THE DOMAIN SERVER.... WHAT IS THE CORRECT IP AND DNS AND SUBMASK...
Hi, Go under network connection Right click on wireless Network connection or LAN connection (depens on what you're using to connect to the modem, a cable or through a wireless connection) and then properties. Scroll down until you see TCP/IP and double click on it. Make sure that it's set to obtain an address automatically and to obtain a DNS server address automatically. If you are using a router, do the same, but in this case you can set a static address. The subnet mask is 255.255.265.0 and the DNS address has usually the same address of your router.
Bye
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Cant connect to dns server
When attemptin to attach to a wireless router
Either the SSID's match between your router and wireless adapter or your router is unencrypted and is attached to by the default configuration that uses the SSID it finds of an unencrypted network.
Now the two machines can talk to each other
If you request a dynamic IP address from the router it's DHCP can pass to your wireless adapter a various pieces of information including an IP Address, subnet mask, default gateway (the routers address in this case), adn DNS addresses (optional)
If you have static addressing in the wireless adapter you must provide to the wireless adapter a IP Address (NOT in the DHCP range of the router and not matching any other device attacned to the network, the same subnet mask as the router, the gateway address of the router and DNS addresses.
The first three of these allow you to communicate with the roouter and establish connectivity with it.
If the router's lan address is 192.168.0.1 and subnet mask is 255.255.255.0 then all addresses of devices connected to the router lan must begin 192.168.0.?. IF the DHCP server in the router can assign 192.168.0.100 - 192.168.0.149 as dynamic addresses. We can assign 192.168.0.2 - 192.168.0.99 as static IP addresses each to one and only one device. There are more potential static addresses above 192.168.0.149 but we will ignore them for this discussion.
The communication band (A, B, G, N) sable by for the router and wireless adapter must have at least one in common
Both the router and wireless adapter must have encryption set the same (WEP or WPA with the same passphrases and options)
If Mac Filtering is enabled on the router the MAC address of the wireless adapter must be loaded into the routers table of permitted MAC addresses.
If there is an error in the IP Address, Subnet Mask, Default Gateway?, encryption, or Mac Filtering, mismatched bands the wireless connection will fail as indicated with limited or no connectivity.
Even if all that works you still are not assured access to the internet.
The DNS addresses and default gateway are needed to be correct along with all the ISP's interface requirements for the wan or modem side of the router to be able to access the internet as and achieve the expected results such as accessing google.
If you would like to work through this step by step we can get you connected however I cannot see what you are doing and anything you do or change that I don't know about until we are done is likely to confuse the process. Please reply to this message if you wish for me to continue to assist.
Dec 18, 2007 | Computers & Internet
How to set a static IP address in Windows behind a Linksys Router
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Accton CheetaHub Classic 2040 Networking Hub Logo
261 people viewed this question
Top Accton Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Accton Computer and Internet Expert? Answer questions, earn points and help others
