Question about Intertherm Heating & Cooling
I am trying to get some information on Intertherm unit on the inside of a Manufactured Home, With the new Hud requirements they are saying the out door unit must be installed by the manufactures installation instructions that comes with the indoor unit, my question is will those installation instructions allow you to install a Trane or a Rheme unit ? I know they will work but are they allowed by the Instructions? Would you know if the Trane or Rheme units are Hud approved ? Thanks for any help on solving this debate,
    President:
  • 1,515 Answers
Hi, since you live in a Manufactured home and not a R.V., I see no reason why you cannot go with what ever type of condensing unit you want to install on a slab outdoors. The installation instructions for the Intertherm unit for installing the outdoor unit should apply to any brand unit you want to use as long as the size of the indoor coil is the same capacity of the outdoor unit. For example, if the indoor unit is a 2 ton, 2.5 ton, 3 ton and so on, the outdoor unit would have to be the same is all. Same freon type, most are R-22, but they are using the new R-410a freon, so make sure of the freon type of the indoor coil is and get a unit of the same size and freon type. The installation instructions for the Intertherm should almost be the exact way to install any other condenser. Look for things like the distance from the outside wall, if it needs to be anchored, how far away the electrical disconnect box has to be from the unit, example 4' to 6'. Things like this you need to look for in the installation instructions is all. The new condenser unit holds enough freon for up to 25' of copper line set also. Try to stay with in that range to the indoor unit. If not, no big deal, they may need to add or remove a little freon is all. I hope this has been helpful to you on this. Trane, Carrier, Rheem, Ruud, Bryant, are all top of the line, better made then Tntertherm in my opinion. They should all be hud approved, I don't know where you are from, but here in Ca, they are.
I wish you the best, and please don't forget to rate me. I know you will be kind.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Posted on Aug 06, 2010
1985 intertherm ultraflex needing a filter for the bottom door to the unit its about an inch thick and looks as if its never been cleaned or replaced Where do I purchase a new filter??
intertherm units were used in many mobile homes. you can google mobile home supply
companies and should be able to find the replacement. Hope this helps.
Jul 08, 2011 | Intertherm Heating & Cooling
I HAVE A INTERTHERM ELETRIC FURNACE FEH012HA IN A 1984 MOBLE HOME.GOT TO REPLACE FUSEABLE DISCONNECT ASSEMBLY .DOES THE NEW UPGRADED MODLE COME WITH WIREING INSTRUCTIONS
The new unit should come with some paper work. it looks to me that its a plug-in unit. providing a link that shows the unit you are replacing. hope this help you. If you need more information let me know and I will try my best to help.
http://americanhvacparts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ELE6210A&Category_Code=EHinte
Dec 21, 2010 | Heating & Cooling
Hello, how do i get an intertherm mobile home heating unit diagram?
Depending on how old your unit is there should be a wiring schematic on the inside of the control panel in the upper left hand corner of burner compartment. Remove two screws to remove cover. I hope this helps you. Thanks
Dec 17, 2010 | Intertherm Heating & Cooling
WHAT IS THE WARRANTY ON THE P3RA-036K? I'VE BEEN IN MY HOME FOR 4 YEARS AND 7 MONTHS. I BOUGHT MY HOME NEW BUT IT HAD BEEN SITTING FOR ABOUT A YEAR BEFORE I BOUGHT IT. EVAPORATOR COIL WAS REPLACED ON...
it should be. but you would need to check with intertherm they make that call. most unit come with a minimum of 5 year parts however who ever put it in and the dealer make final call so its to gray to say sorry if you explain your concern to intertherm they may give you an extended warranty it happens sometimes if customer feels cheated please give me a rating and vote
Sep 21, 2010 | Intertherm P3RA-036K Air Conditioner
I have a Intertherm outside AC & it was put in when the mobile home was built(1982) and I do not know what it is, I only can find the name of the manufacture, where would I find the model, & other...
mobile homes have split units, I would check the unit inside to see if it has any information. I would check all breakers inside and out, and thermostat. Hopefully it will be something simple. Good Luck Tim
Aug 09, 2010 | Intertherm P3RA-036K Air Conditioner
We have an Intertherm furnace in our manufactured home which is apparently a replacement furnace as this is not the brand showing on the original paperwork for the home. Problem is that it is very loud. ...
That is a common furnace for manufactures homes and yes they are loud....that is because there is no return duct on the unit and the fan sits jsut inside the door so the noise is not contained...
short of moving the furnace there is not much you can do about it...yes it stinks I agree with you... wish I could give you better news...
heatman101
Aug 08, 2010 | Intertherm P3RA-048K Air Conditioner
Where are the furnace filters in my older furnace?
Open the door to the airhandling unit inside the closet by lifting upward on them. There should be two filters located on top of the A coil.
Dec 05, 2009 | Heating & Cooling
HUD will not light up
If you peek down inside the windshield, you'll probably see the HUD is working. A common issue is that the adjustment spring will break, making the HUD invisible because it is adjusted out of range. The spring can be replaced by removing the cluster then the HUD unit.
Aug 13, 2009 | 2004 Pontiac Grand Prix
I have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Mar 17, 2009 | Heating & Cooling
Heating & Cooling Logo
162 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
