Question about Dell Dimension 3100 PC Desktop
Lost sound on my home computer after kids were fiddling around. all speakers connected and powered on. pls help
    Genius:
  • 2,785 Answers
Plz check in device manger the sound driver is installed or not, if there is yellow question or explanation mark then you have to reinstall the driver for the sound, if there is no mark in the device manger then check the volume controller if it is muted. post back if required
Posted on Aug 06, 2010
Static sound builds up in the sub pops, then no sound comes from it. The sound comes back once I reconnect the power source and fiddle with the power plug. The problem then repeats.
Look for a wire strand or solder splash on any circuit boards or connections that might be 'almost' shorting out anything. Next, if there are any metal screws with very pointy tips (like sheet metal screws) that might be just a smidge too long and clip the very tip off so that it can't possibly short a frame to a component.
The idea is to find any reason why electricity might be bleeding over into another area of a circuit board that uses capacitors where a charge could build up causing the symptom you are describing.
May 09, 2016 | Altec Lansing Audio Players & Recorders
My computer lost sound. Audio driver ok. Speaker ok. volume controls ok. Motherboard: Lenovo, Columbus. Pls. help me! darabugan@yahoo.com thanks.
check for the Audio Output port for any damage. Make sure the speakers are connected to the Green Output port. Reinstall the Audio drivers if neccessary.Try good known speakers if you have one.
Nov 13, 2009 | Computers & Internet
I've lost sound in one speaker
Check the wire for frays, missing insulation, broken area, loose fitting, etc. It sounds like there is something that is not making a proper connection. "Fiddling" makes it better leads me to believe that a bent area, frayed wire or such has it not making a full connection. You may need to replace the wire to that speaker in order to correct the problem. If the unit is still in warranty I'd suggest contacting a Logitech repair center for this. If it is not then you can do this yourself if you are comfortable working with a soldering iron. Just make sure you use properly rated speaker wire and connect the wires properly. Hope this helps.
Sep 13, 2009 | Logitech Z-2300 Computer Speakers
No sound from speakers, loose connection in green jack wire.
Yeah man I have the same problem!
I guess I will just buy a new jack!
May 27, 2009 | Logitech Z-640 5.1 6-Piece Home Theater...
Stopped working
Sorry I don't have a solution, but the speakers have done the same with us. Power comes on, some sound like the wire shorting out, but otherwise no sound. Tried different connection wires, different computers (mac and pc) but no go on any of them. So, I also don't think it has anything to do with you deleting some files.
May 11, 2008 | M-Audio StudioPro 4 Main / Stereo Speaker
No audio from dvd player
you wil get the sound from the surround speakers only but not from tv first connect all the speakers that are given to the player correctly then you can get perfect sounds with dts...
May 04, 2008 | JVC TH-A25 System
Speaker has sound when powered .
Hi , open the control panel /select to classic view,select add hardware to locate some drivers cyber acoustics speaker just follow the instruction to connect the speaker.
check also the device maneger the connection of the device.
Jan 11, 2008 | Cyber Acoustics CA-3000 Computer Speakers
Dell Dimension 3100 PC Desktop Logo
77 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
