Question about Quasar HQ2141RH Air Conditioner
No longer cools the air adequately even at max setting
  • Quasar Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 06, 2010
Generator no longer puts out 220 so longer runs my whole house air conditioner?
it could be just that it needs the rpm adjusted to maintain the 220-240 volts under load
if you have a large air conditioner , then it will be at the load limit for the average 7.5 kva gen set which has a max constant output of 6 kva
you can get the wattage requirement of the ac from the specs plate on the outside unit
Jan 31, 2018 | Heating & Cooling
Replaced heater core and thermostat. Im getting no
make sure all the air is bleed from the cooling system and its full. if this is good then you may have a water pump problem like worn impellers or a broken water pump not circulating the coolant.
Oct 10, 2014 | Cars & Trucks
What exactly does max a/c and norm a/c do; the difference, and performance? What does recirc do and why is it available during max, norm, and bilev but not during defrost? The same a/c properties are...
Hello: Max cooling is when the recirculate door opens. With the recirculate door open, 80% of the air flow comes from inside of the car and 20% is outside air. That makes the cooling more efficient. Normal a/c operation is 100% of airflow comes from the outside. These settings have nothing to do with compressor operation. Also Decreasing or increasing the amount of cooling has nothing to do with compressor operation, what that does is control the amount of air going from the evaporator core either through or past the heater core. The a/c compressor runs the same amount of time regardless of settings on the control panel. Also in cool weather the compressor runs in the defrost mode to keep the windows from fogging up. None of these settings affect performance, the only time performance is affected is wide open throttle (WOT) in that mode the engine computer shuts off the compressor to allow max power of the engine, ie: passing gear.. When A/C is selected the compressor is on, none of the settings will affect gas mileage, ie, low/high, max/normal 60 degree or 90 degree.
Jul 22, 2011 | 1997 Buick LeSabre
Should the GWU523 get hot?
Most wireless adapters will get hot during use.
Obviously the cooler it stays, the better it will operate and the longer it will last, but as long as there is adequate air flow around the device for cooling and the ambient temperature is reasonable, it should not be a problem.
Excessive heat may cause occasional loss of signal / connection or even total failure eventually, but unless the unit becomes to hot to even touch, it should continue to operate normally.
Hope that was helpful.
Jul 04, 2011 | IOGear WiFi 54g GWU523 802.11g/b Wireless...
Freezer is very cold refrigerator is not cold as it should be
Check your temperature control (Thermostat) settings. If it is not on high/max cool then set it just less than the maximum. If it still does not cool then I am afraid the problem is of less cooling gas. You have to ask a technician to check and refill.
Feb 23, 2011 | Kenmore 74209 Top Freezer Refrigerator
2001 ford ranger problem
It sounds like you need to get your air con re-gassed. take it to a GOOD garage, they should do it for a little amount.
Jul 20, 2010 | 2001 Ford Ranger Regular Cab
My Ge Monogram Refrigerator required maintenance cleaning on the condenser, typical with this type of built-in system. blew out the dust and cleaned it. the freezer is working fine but the refrigerator...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 18, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
No heat unless set at max temp. setting.
Hey Summers,, Are you running the A/C with the temperature set at max heat?? If yes. STOP... the A/C is for COLD air..As far as the fan speeds not working....you may have a fan switch that is going bad..(my vehicle is doing this!)..
Jun 16, 2017 | 1999 Oldsmobile Bravada
Heater stays at max temp, air conditioner hot except on max cool.
it sound like one of the flap in the duck work is not working. check your heat contrell unit in the dash
Mar 22, 2009 | 1998 Mercury Mountaineer
No cool air and oil in one of the drain lines
I would say that you have a refrigerant leak. The oil was pulled out of the compressor and leaked out with the refrigerant.
Jan 17, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
57 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
