Question about Samsung Refrigerators
What is the temperature for the refrigerator? How can I change it? I do not have the manual, how can I get a copy? Thank you. Alba
  • 525 Answers
As you change number for thermostat , at the same time you change the temperature inside
Posted on Aug 06, 2010
Brand new having difficulty adjusting temp settings for refrigerator and freezer
Hello Joan, thank you for your post!
Based off the information you have provided you are experiencing an issue with adjusting the temperature settings for your Frigidaire refrigerator. Is your refrigerator not allowing you to change temperature? Or when you change temperature does it not change? If you could provide any additional information on your refrigerator I would be happy to help you further. -Matt
Aug 26, 2015 | Frigidaire Professional 27.8 Cu. Ft....
How do I change temp readout from c to f on a refrigerator frigidire that is 10 years old model FSC23F7DSB
Hello Joel, thank you for your post!
I understand that you would like to change the temperature readout on your Frigidaire refrigerator, FSC23F7DSB. In order to change your temperature display you need to hold the fresh food arrow up and then press the freezer up arrow 3 times within 5 seconds. I hope this information is helpful. -OOS
Mar 18, 2015 | Frigidaire Refrigerators
Panel states HI for Freezer
Hello Sherra, thank you for your post! Typically error code HI indicates that the refrigerator has detected high temperature in freezer. Generally speaking, the recommended factory setting is to be set at 0 for the freezer temperature and 37 for the fresh food temperature. You may try resetting the refrigerator by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and then turn the appliance on. Set the temperature to a lower setting and please allow 24 hours for the temperature to stabilize. The refrigerator should then resume to normal operations. I ask that you please follow up with a comment on the post, at your convenience to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Aug 13, 2013 | Electrolux EI27BS26JS Stainless Steel
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
Alba CXDAB202 manual needed
Hi Peteter:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 09, 2012 | Alba Televison & Video
I have a ge profile side by side refrigerator model number psc25psta. The freeze is not getting cold. How do I reset the temperature.
Here is a link to the main GE Support page for your refridgerator:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PSB42YSXSS
And here is a link to the Online User's Manual with the operating instruction for it:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60558.pdf
See page 5 of the User Manual for detailed instructions on how to adjust the fridge and freezer temperatures. It reads as follows in the manual:
To change the temperature, press and release
the WARMER or COLDER button. SET will illuminate in
the display, as well as the set temperature. To change
the temperature, tap either the WARMER or COLDER
button (while SET is illuminated) until the desired
temperature is displayed. Refrigerator temperatures
can be adjusted between 34F and 47F and
the freezer temperatures can be adjusted
between 6F and +8F.
Once the desired temperature has been set,
the temperature display will clear after 10 seconds.
To display the temperature, the DISPLAY TEMP button
may be tapped.
Several adjustments may be required. Each time you
adjust controls, allow 24 hours for the refrigerator to
reach the temperature you have set.
Good luck and please comment back here and RATE 4 Thumbs Up if this was at all helpful.
Just click on the highlighted links with your mouse in order to access the information described.
If the link does not open properly, you may need to download a PDF Reader program for your computer. The best reader can be downloaded free at www.adobe.com where you just click on the DOWNLOAD ADOBE READER button on the right hand side of the page and follow the on-screen instructions.
Just comment back here if you require any further assistance, I will be pleased to assist you in any way I can.
Thank you very much.
Joe.
Feb 14, 2011 | GE Profile PSB42YSXSS Stainless Steel (252...
I have purchased an alba sl1231 digital camera and cannot access the cd rom instruction manual as i have a notebook laptop without disk drive, can i download instructions?
It seems that looking for any support from Alba online is a fruitless exercise.If I was you, I would take your CD to a copy shop and get them to print the manual for you.
Jul 19, 2010 | Cameras
Alba dvd
check on the system menu under preferences, there is a option there if that helps
Dec 22, 2007 | Alba DVD-108 DVD Player
Refrigerators Logo
46 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
