Unmountable boot volume error. Not able to boot from installation disk, no floppy drive on laptop available. Has the hard drive died?
  • 1 more comment
  • jvdmeij Apr 27, 2008
    Thanks for that, I was afraid that that would be the case, as the laptop does not respond to anything.
    If restarted and pressed F2 as you suggested, and where it reads "USB HDD:" in the boot diretory, no text is entered, so that pretty much confirms the Hard Drive needs replacing I take it?
    Regards,
    Jose.
    Thanks for that, unfortunately I am not able to reboot my installation disk, so I don't get the welcome screen either. I have no floppy disk drive installed. The F2 function has confirmed there is no entry recorded against the "USB HDD". I think this has now confirmed that the hard drive needs replacing.
    Regards,
    Jose.
    Thanks for that, you have been a great help by confirming what is wrong and showing me where to look. Fortunately, the laptop is still under warranty and all data was recovered before it crashed. (I've learnt my lesson from a previous experience).
    Have a great day.
    Regards,
    Jose.
  • 689 Answers
1. Insert your WindowsXP disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode black screen like DOS
3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted.
When asked to say yes or no, type the Y key on your keyboard.
5. Type exit and press the Enter key to reboot your computer.
Please post the outcome if issue persist. Rate accordingly if issue has resolved.
Good Luck
Posted on Apr 27, 2008
    Genius:
  • 3,587 Answers
Yeppers..it's toast..you may be able to recover it with a data recovery company..
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Apr 27, 2008
    try going through F2 first, to see if it's still there
  • Patrick Michaels
    yes it does..and you may be able to recover data..
  • Patrick Michaels
    thanks JOse..you lucked out..remember to rate the expert you think helped you the most
UNMOUNTABLE BOOT VOLUME ERROR ON GATEWAY GM5045E WITHOUT RECOVERY OR WINDOWS XP DISC.
An unmountable boot volume error suggests that you may have a hard disk failure or at least some corruption to the hard disk which the system uses to boot Windows XP.
To try to resolve this problem you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) then would need to be burnt on to a blank CD then the computer booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need a Windows install CD or other recovery CD media.
If HDAT2 finds a lot of unrecoverable errors then you should seriously consider replacing the drive - you should be able to recover data from the old drive using other tools on the Hiren's Boot CD, including booting the CD mini-XP environment and using the tools there too.
Dec 29, 2011 | Gateway GM5045E (RBGM5045E) PC Desktop
My ibm thinkpad will not start up, even in safe mode. unmountable boot volume keeps coming up
Hi there.
Remove all usb flash drives or external hard drives connected to the laptop.
If no flash drives or external hard drives are present the you will need to reboot your system and press the delete key repeatedly until you get into the BIOS. Once in the BIOS you will need to locate boot disk priority. Set priority 1 to the laptop's main drive and priority 2 to the CD/DVD drive.
Now it should first try boot on your hard drive with your operating system on it. If after this you still get the unmountable boot volume error then your hard drive may be corrupt.
~ Slasher_X
Sep 25, 2011 | IBM ThinkPad T42 Laptop
UNMOUNTABLE-BOOT-VOLUME DELL LATITUDE D610 technical information: *** STOP:0x000000ED (0x86D3A900,0xC0000006,0x00000000,0x00000000)
Good day. Regarding your issue, computer hardware wears out over time, it's a fact. Your hard drive works constantly reading and writing data, and this (among other factors) may cause errors on certain parts of your system. If you receive the "unmountable boot volume" error and have an installation disk, you still have a chance to save your system.
1. Insert your XP installation disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
3. Now type chkdsk /f or /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
Note: other windows version like Vista or Windows 7 have a Repair option once you use the installation disc to fix this problem.
Hope this information help in resolving your issue. Have a great day.
May 23, 2011 | Dell Computers & Internet
Unmountable boot drive error on 80 gb hitachi laptop drive
If you receive the “unmountable boot volume” error and have an installation disk, you still may have a chance to save your system.
If all went well, you should now be able to boot back into Windows without a problem!
Aug 23, 2010 | Hitachi hts548080m9at00 80 GB Hard Drive
I'm getting a stop error code 0X000000ED,0X86714368, 0X0000006, it's on a Dell Latitude D600 laptop?
Unmountable boot volume indicating that the system cannot successfully read the boot sector of the hard drive.
Run the diagnostics on the hard drive, if it fails, replace the hard drive.
If diags pass, boot to the recovery console, run chkdsk /r If it still gives the error after that, you can try reinstalling windows.
If that fails to resolve, then again, replace the hard disk drive
Nov 19, 2009 | Dell Latitude D600 Notebook
When my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Oct 18, 2009 | Gateway MT6705 Notebook
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Sep 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
Will not load windows I get an error message stating unmountable boot volume
i) i think you hard disk or hard drive(of your laptop or desktop) is malfunction or not working properly.....
   or it has gone bad, i think you have to send it for repair or replacement;
   error messge: unmountable boot volume is specifically for harddisk malfunction and requires repairing or replacement(strictly)
Thanking you
M. Sridhar
Dec 29, 2008 | IBM ThinkPad 600E 2645 Notebook
Computer won't boot into windows
The event of you inserting a DVD is unlikely to have anything to do with this problem. Probably just a coincidence that it happened after you did so. Hard drives die eventually and more frequently so in laptops.  I'm afraid you will have to bite the bullet and replace the hard drive.
Dec 11, 2008 | Dell Inspiron 300M Notebook
Boot volume err
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Oct 18, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
