Question about Breville 8459414 Blender
Base of blender got wet,water spilled down from top, when turned on, red light went on, started then made a click sound and shut off, now won't work.
Why won't my ninja blender turn on? The red light is blinking, but power is connected and lid is secure.
try rotating the container part 1/4 of a turn to line up slots and press down . then if it does not blend turn another 1/4 turn to line up slots and press down pushing container into base motor unit .
container and screw on blade lid is put in upside down and the plastic posts have to match the base unit to turn on the blender when you press down on container into base unit.
I own and use a ninja blender !.
May 08, 2018 | Blenders
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Power light is blinking and the blender will not work
Align the arrows on lid and handle, and latch it down before you put the pitcher on the base and spinning it to lock it in.
Mar 18, 2014 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
Mar 14, 2014 | Krups KB790 Blender
Blender now only has one speed and it's overspeed. Is there an overspeed govenor that causes the blender to automatically shut off? It will overspeed about 3 seconds before it stops working and all the...
there is a voltage regulator inside the circuit board , this might have got wet some how . this circuit controls 1-10 speed from a touch of a button . will have to disassemble unit , Auth personal should check this , unless you know electronics
Mar 19, 2010 | KitchenAid KSB3 Classic Work Top Blender
Spillage onto base of blender!
Usually leakage into the base can compromise the motor's performace. Since it sounds like this also has digital displays, you don't want to risk messing it up even more by turning it on. The company should have service places you can take it into to get checked out, some might even do an estimate for free. I would call the company and see if that's possible and maybe just a quick cleaning can fix it.
Mar 05, 2009 | Krups KB7207 4 Speed Blender
The red light on my blender keeps flashing but when i press any other buttons it just beeps twice and does nothing.
inside the jar ring base (turn it upside down) you will see little white tabby things in the slots, at least one of them has to be lined up with the 2 small grey contact points on the base of the blender.
I had this same problem!!
you can contact me at jureed@rochester.k12.mn.us
Julie
Jan 26, 2009 | Oster 6700 Work Top Blender
Power flashes but doesnt start
Yes, I know what it is. On the base of the blender jar (the plastic base) there are some "fingers" that must contact the base to allow operation to take place. Turn it upside down and look at the little plastic "fingers" around the outside periphery of the plastic base.
These fingers tend to break over time... mine only has two left right now, and it only works in one particular position as a result.
Rotate the blender jar one spot at a time until you are able to operate it "normally". I use it for margaritas, and it won't allow me to push the button for Frozen Drink unless the jar is in the right position.
I am going to try and find a replacement base (or entire blender jar) somewhere... or else I will finally have to retire my favorite blender of all time!
Dec 20, 2008 | Oster 6700 Work Top Blender
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Dec 28, 2007 | Waring BB180 Work Top Blender
Breville 8459414 Blender Logo
1,008 people viewed this question
Top Breville Blenders Experts
Mike
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
