Question about Dell 968w Printer
Comes out blank at other end - Dell 968w Printer
  • 64 Answers
Have you removed all the tonner cart covers, they have a strip that need's removing to allow toner to fall onto the drum.
Posted on Aug 06, 2010
Printer sounds like it is printing but paper is blank when done
gabriel, have you tried to 1. clean and 2 allignment of cartridges using the tool function.?
Mar 24, 2014 | HP F4480 All-In-One Printer
How to execute double sided copying
When the page comes out of the printer, turn it to the other (blank) side, insert it into the clean paper holder with the blank "top" at the same end as the already printed top. Then tell the printer to Print again. The procedure could vary somewhat, depending on the make and model of printer.
Feb 22, 2013 | Office Equipment & Supplies
Outgoing fax was received as blank
Make sure that you sent the fax face down.
If all your faxes are sent blank, there may be a problem with the scanner. Try making a photo copy placing the page face down, if your copy comes out blank then the scanner is finished.
If your photocopy does not come out blank then the problem is on the other end and not your machine.
Thanks,
Pat
Aug 16, 2010 | Brother IntelliFax-2820 Laser Fax
If we send afax than it is coming blank at another
make sure you are placing the document in the feeder correctly. some faxes you have to send it face down others you have to send it face up.
Aug 06, 2009 | Brother Office Equipment & Supplies
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Windows loads then screen goes blank
Press Ctrl+Alt+Delete then when task manager comes up, look under processes, if "explorer.exe" is running end the task.
Next, go to File>run and run "explorer.exe". This should bring up your desktop and icons.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
Jan 20, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Cleaning flex cable on Razr
The FLEX cable doesn't ever need to be cleaned. If your screen became blank it's probably because (among other things) the flex cable IS broken, not dirty.
May 05, 2008 | Motorola Mobility RAZR V3
Blank screen (led indicator is orange)
it could be the cable from the monitor to the pc it is defactive try a new one cuz if the monitor works then it is the cable that is makeing your screen go blank
Oct 10, 2007 | IBM E74 17" CRT Monitor
Personal copier problem
Hi,,Could be the Transfer Corona unit that is shorting out through the end blocks.[High voltage unit] You get a fizzle sound most often when it is copying.. You can remove the unit and scrape the burnt track from the plastic end block. Dave,, Ulster,, Northern Ireland,,
Mar 20, 2007 | Canon PC160 Black and White Copier
Open Questions:
Dell 968w Printer Logo
51 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
