Decide on where you want to put the hangers/anchors then check to see if there are any window braces in the wall that will support the hangers. If so hang the anchors. If not find where the inner window frames are and adjust the position of the hangers.
There are recipes for homemade bird seed treats that involve suet or some other sticking agent that keeps it together so you can hang it in a lump. But I came across a very cute web posting with a recipe for a bird seed treat that is heart shaped! Check out this link http://kids.nationalgeographic.com/kids/activities/crafts/wild-bird-treat/
depending on the application the cables can be inserted into slots first you need to put the hanging cables around what ever you choose to hang this light from using the loop run the other end through the loop drawing the cable down to the bracket insert attach to the light raise it to the desired height there should be also in this kit a hanging adjuster this needs to be put on as well before hanging light I wish I could show you hard to describe it
Fault in the phone software, try to remove off battery forr half an hour and reset it back, check your memory card for faulty files, virus.scan in your pC. Put battery on set restore to factory settings.check ,if OK put back the memory and try,
If not the phone software may be faulty with some errors.
Does it seem to hang low or does it actually hang low? Readjust
it. There is a switch that may hang high when the door closes.
You just have look at what does what and what ain' doing what it is
supposed to. first.
