Question about Aiptek HiSpeed 720p High Definition Camcorder HISPEEDHD
My camcorder does not start when i open it.And reacts on nothing! The accumulator is charged and the device did not become in someone Manner damages.
I have received as a gift a Canon FS300 Digital Video Camcorder . The first time I used it, I followed instruction on how to charge the battery with CA-570 Compact Power Adapter which was included. It wok...
Hi!
Almost sure there is nothing wrong with your battery, charger and camcorder.
The battery loose power even when doing nothing, especially when it is a NiMH type.
Please charge the battery for a couple of hours and try again to start the camcorder.
Aug 09, 2011 | Canon VIXIA FS300 Flash Media Camcorder
I have Canon VIXIA HF10 camcorder. Recently, it stopped opening lens shatter window. Please help..........
The device relies to an extent for functionalities the batteries to attain shutter lenses displays. Batteries that have been depleted of power storage require full charge to restore the features that may have required extraneous power to perform. Also, performing full charge to batteries that have been depleted of chargeability's may require replacement altogether. Refer to the devices user guide to ascertain the battery duration requiring replacement. Also the user guide would provide the diagnostic that makes operational the malfunction device. Once unachieved success to restore the malfunction, the manufacture of the device may become means to resort. The contact details are attainable from the device user guide. Contacting the device manufacturer makes available the support expertise familiar with products. Also, the product that is within guarantee or attained warrantee is capable of resolutions agreed at acquisition. The malfunctioning device should least be resolved by an alternate establishment without the manufacturers resort to reestablishment.
Feb 05, 2011 | Canon VIXIA HF10 HDV Camcorder
CANNOT OPEN THE iNTELLI-sTUDIO PROGRAMME
Also had this problem with windows 7, Go in to "Devices and printers" If your camcorder is recognised there ie "Samsung Camcorder" Right click it you should be given a menu with several options choose "Browse files" then "CD Drive (*) intelli-studio" this opens the software installed on the camera, go down the list and find "setup_f" double click this and this should start the install process, it will probably tell you there is a newer version and ask you if you want install this select yes and hopefully this will then install the program , Hope this helps someone . Colin
Jan 24, 2011 | Samsung SMXF40 Camcorder
I have sharp VL E630 the battery is charged I put it in the camcorder the screnn fickered a couple times the went black and now nothing? Allan
Many times the contacts that hold the battery in place become compressed and they no longer make good contact. This results in not only the battery no charging often, but the camera not working. Make sure that the metal tabs are holding the battery securely.
The other possibility is a short. This is much harder to troubleshoot and may require you take the camera in for repair. But if the device has a short, it will shut the camera down.
May 05, 2010 | Sharp VL-E630U Camcorder
Flip camcorder - all software gone
Perform the suggested format, using the device as recognised on USB - don't worry about it not being the flip icon.
Mar 07, 2017 | Pure Digital Flip Video Ultra Camcorder
Navman F10 not starting
Apparently, according to the Navman helpdesk you have to open NavDesk and from the menu, go to Tools and then Recover Keys .
I tried this on my S80 and I got an error, (E000050) which I was then told I had to send the unit back for repairs. This is my worst purchase ever. I'm on my third unit and have had nothing but trouble.
Dec 06, 2008 | Navman Tracker 5500i GPS Receiver
Panasonic dvd camcorder
can you hear a rattle when you shake the unit? Listen carefully!There is a screw that comes off and creates this problem. Can be fixed by the service centre as you have to open the system.
Jun 22, 2008 | Panasonic VDR-D100 DVD Camcorder
Not responding......help
Low or flat battery. Connect to mains charger and fully charge.
May 27, 2007 | Navman PiN 570 GPS Receiver
Machine just shut off when opening the cassette door. Locked up!!
look for a tiny pinhole and insert a pin while powered up to reset the device
May 27, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Nothing on screen
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. it is complex you need to send it to the service center.
Dec 14, 2006 | Konica Minolta DiMAGE X50 Digital Camera
Aiptek HiSpeed 720p High Definition Camcorder  HISPEEDHD Logo
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
Michael Galve
Michael Galve
Jose Ma DM.
Jose Ma DM.
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
