I tried several times to run a CD movie in my old Windows 98 computer -- but failed. With audio CD there's no problem. What type of media player should I use ? I remember I used to watch movies with this old computer years ago - can you explain to me why.
    President:
  • 563 Answers
Hello.
That is possible that your CD-ROM or DVD-ROM drive has been corrupted or deleted from the PC.
Try to re-install the windows by using the CD or upgrade it to windows xp.
It can also be that your PC doesn't support VGA or higher-resolution monitor (16-bit or 24-bit color Super VGA recommended) and thats why the CD won't play.
Try to check whether it can play old and new CDs or DVDs besides the one you have inserted.
If all the different CDs/DVDs you have inserted won't play, its possible the driver is required and you need to reinstall it.
As for audio, its different.
If you audio card and speakers are good, you won't have any problem listening to audio/.
Posted on Aug 06, 2010
My cd/dvd romwont read and play pc gamed or movies
The cd/dvd driver will probably need to be replaced, first! get some rubbing alcohol and a Q-Tip, now gently clean the laser lens and allow several minutes to dry, if this fails! the driver must be replaced. Go to www.ebay.com Type: make and model of laptop and refine search to CD/DVD driver.
Apr 26, 2012 | Acer Aspire 5732Z-4855 Notebook
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
CD Player in caravan doesn't play burned cds.
the CD player is a clever one thats looking for the copyright on the CD .Try using nero to burn the cd that oftens fools the player ,or an old computer with windows 98 on it with a copy of the old nero or windows media player that come with windows 98 as the later versions will not work with a lot of expensive players .if it has a line in plug then use a i pod or your mobile phone ,if it has a tape player then use a cassete with the wire coming out that plugs into a audio device ,i use my mobile phone which has a 1gb memory card in my jag as i have the same problem with the cd player ,also in the every day car my escort i use this as iam fed up with having the window broke and cd player nicked .But i have found that burning cds with an old computer with windows 98 i can burn cds that will play in the jag ,not that i use it a lot cant affords the petrol here in spain at 5 dollars a gallon
Aug 01, 2010 | 1999 Dodge Caravan
Does not recognize DVDs, computer
I would like to suggest that you attempt to download & install the codecs that your media player requires, before it will play a DVD.
I found this typical when I was using the Vista operating system with Windows Media Player 11.
The codecs can be found as freeware online & a good site for the apt codecs for WMP 11 is @ www.majorgeeks.com once you are on the site, click multimedia on the left of the page, then scroll down to the codecs required.
The K-Lite series of codecs seem to work well with WMP 11 on Vista.
I truly hope that this has resolved your problem, as there is nothing better than watching a fine movie on the old PC.
Failing my advice, you could always 'Rip' the said movie to your media player & view it from your hard drive.
Good luck anyway.
Warmest regards,
Ste
Apr 18, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
I cant watch videos on my computer no more why?
do you have video software installed ? Real Player, Jet Audio, Windows Media Player .......etc
make sure you have them and if you're trying to play a move, look at the extension ( Name.WMV) .WMV is for windows media video, which works on windows media player. you have to have the right program to play the video you want depending on the extension.
I have Jet Audio, its a very good program that can play many types of movies. you just go to preferences ---> file type associations ---> then check all and it will play almost any video or audio file you have. without needing to download all other software. One For All
Jan 03, 2009 | Computers & Internet
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
A DVD burned with Studio 10.8 plays on our stand alone DVD player, but it won't play on our computer.
check what mode the cd video is you may have to burn another one with the correct mode for pc
Right click program on cd go to properties check video name plus what is after the . ie home.wmv as you need to burn cds with a general code
Try VLC Media Player on computer this plays all my video media
Jul 22, 2008 | Pinnacle Systems Studio AV/DV Version 9...
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
May 10, 2008 | Jensen CD-2010X CD Player
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Computer
- This device also works with Windows 98 SE and Windows ME, apart from Windows 2000 and XP. Make sure all the critical updates are installed on your computer - To put songs from a regular audio CD to the MP3 Player, you would first need to convert the songs from the audio CD in MP3, WMA, Ogg or Audio ASF format. The songs in audio CDs are in CDA format. good luck
Apr 04, 2007 | Samsung YP-U2X Digital Media Player
Computers & Internet Logo
David Payne
David Payne
