Question about Datamax I-4208 Thermal Label Printer
Password reset for datamax i 4208 printer. locked out of printer and do not know the password.
Sysadm
Posted on Feb 18, 2011
  • Jason Koelling
    Jason Koelling Mar 21, 2013
    4 digit passcode?
  • Brian Robertson
    Brian Robertson Sep 20, 2013
    Did you ever find this 4 digit code?
HOW TO FIND THE ip ADDRESS ON A DATAMAX i-4208
To view or set the IP Address on a Datamax I-4208, use the Front Control Panel on the printer and follow these steps:
Press Menu, go to Communications, then NIC Adapter, then IP Address.
Jun 19, 2014 | Datamax I-4208 Thermal Label Printer
Zpl emulation with datamax i-4208
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Able Label Systems Thermal Printers
Feb 01, 2013 | Datamax I-4208 Thermal Label Printer
Datamax I-4208 has different position than i-4308 or prodigy max
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Feb 17, 2012 | Datamax I-4208 Thermal Label Printer
How can I upload the logolab.bmp from linux to the datamax I-4208 printer?
Assuming you want to print the file use the command "lpr" This is the only protocol used by this printer anyway.
If you have root access to the printer you can use "lp" but otherwise use "lpr"
command line usage:
"$ lpr logolab.bmp" please let me know if this helped or if I can clarify more.Joe
Feb 17, 2011 | Datamax I-4208 Thermal Label Printer
Datamax i -4208 printer
Any Thermal Transfer or Direct Thermal label on a 3" i.d. roll with maximum o.d. of 8" and label width between 1" - 4". Thermal transfer labels require appropriate ribbon.
Nov 24, 2009 | Datamax I-4208 Thermal Label Printer
Datamax i - 4208
If you use ms-access you must have installed the windows driver, therefore you must enable the cutter in the printer properties. Position fault is that it does not detect the label, must be press the FEED key or to calibrate, press the FEED key for 5 seconds to calibrate the sensor label.
Sep 01, 2008 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 Thermal Printer.
I have seen quite a few bad nic cards from Datamax, and that may be the problem.
If you can set the card from the printer, then it is seeing the card as it reads directly to the processor when inserted. But the card can still be bad if you cannot ping from the outside.
Jan 12, 2008 | Datamax M-4208 Thermal Label Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 Thermal Label Printer Logo
3,109 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
