Question about Dishwashers
WHAT IS ERROR CODE F4 ON AN ADP 8800 - Dishwashers
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It means that the dishwasher is not draining properly, not draining at all or taking longer time to complete the cycles. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. If there is a large amount of water being retained in the dishwasher then there is an issue with it. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
Code F4 dishwasher whirlpool ADP 7590
i think f4 is a drain error check the pump has no blockage ie broken glass/pottery etc. hope this helps
Feb 03, 2012 | Whirlpool Washing Machines
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Error code F4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 04, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Error code f4 on my adp 5966 whirlpool dishwasher
Blocked waste outlet or maybe just a worn pump.
I fixed a new one today showing F4
I found a piece of broken glass stopping the waste pump.
Hope this helps
john
Aug 05, 2008 | Whirlpool Dishwashers
How to use auto cut for ADP-300 urgent
dear sir / madam
i am mohamed anver azam mohamed currently we are using a adp 300 pos printer i needed a pos printer driver if you can plase post to us
129, hospital road,kurundugaha ela, akurana , kandy, sri lanka
May 06, 2008 | POSX POS-X ADP-300 Matrix Printer
Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
We had same problem with our ADP 5966. An engineer over the phone said he thought it was related to machine being unable to drain. I checked the drainage pipe connection to u-bend under sink, and sure enough, there was a major blockage. Cleared that and hey presto, problem solved.
Jul 31, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
