Question about HP DeskJet F380 All-In-One Printer
F380 auto power off after a few scan... Cannot power on again... Have to wait a few days before it works again. But only allow me to scan a few pages and problem again!!!
I have been having the same problem. I have discovered that turning printer off when not using it works pretty well. If I forget, I unplug the A/C from the power adapter for a few minutes (2 - 3) and the printer usually powers up then. Some times I have to repeat these steps. Not a good fix, but at least it becomes usable. I suspect the power supply may have an overheat issue, maybe marginal capability. I look for fixes every few months and found this posting. Thanks. Bill, 25 years in MIS/IT
Posted on Jun 22, 2008
    Problem Solver:
  • 9 Answers
The scan function might not work correctly if the Digital Imaging Monitor (DIM) is not running. Follow these steps to make sure that it is running.
  1. Click the Start button, type run into the Start Search box, and then click Run in the Start menu.The Run window opens.
  2. In the Open box, type MSCONFIG and click OK . The MSCONFIG utility window opens.
  3. Click the Startup tab.
  4. Select HP Digital Imaging Monitor . If it is already selected, continue to the next solution.
  5. Click Apply , and then click Close .
A message to restart the computer appears. Click Restart to restart the computer. It will work and the issue is resolved.
Posted on May 28, 2008
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
Unable to print or delete a document
  • 1
    Remove the cartridges from the F380 printer.
  • 2
    Position the cartridges so they are right side up and the gold leads are facing you.
  • 3
    Place a small piece of tape over the gold contact in the top left corner of each cartridge.
  • 4
    Place the cartridge back in the F380 printer. The printer automatically prints an alignment page.
  • 5
    Remove the cartridges. Place a piece of tape over the gold contact in the top right corner of each cartridge.
  • 6
    Place the cartridges back into the F380 printer. The F380 prints another alignment page.
  • 7
    Remove the cartridges from the printer. Remove both pieces of tape from each cartridge.
  • 8
    Insert the cartridges into the F380 printer. The printer prints a cartridge alignment page. Each cartridge is now recognized as a full ink cartridge.
  • Jun 16, 2011 | HP DeskJet F380 All-In-One Printer
    Ink cartridge light of mt HP Deskjet F380 All-in-One is blinking and an E appears, have tried replacing cartridges and everything, but no result whatsoever.
    Hi
    Please try this solution
    Remove the USB cable into the printer and leave the printer on.
    Remove all the cartridges.
    Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
    Disconnect the power cable and from the power source supply.
    Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
    Reconnect power cord and turn on the printer.
    Return all the ink cartridges and close the door. Wait for the calibration process.
    Print the test page to check if it working.
    Reconnect the USB cable and try to print again.
    Post comment if you need more help. Regards
    Apr 09, 2011 | HP DeskJet F380 All-In-One Printer
    I cant scan
    All support for the F380 AIO-printer is on next site:
    http://h10025.www1.hp.com/ewfrf/wc/product?product=1128296&lc=en&cc=us&dlc=en&lang=en&cc=us
    Scan function might be not working, having no scan software installed.
    1. Download software plus updates for your printer.
    On the support page select:
    Software & Driver Downloads
    Operating System
    > Download the Full Feature Software: this should contain software for
    both printer and scan functions, to a location on the computer
    > Download updates, to a location on the computer
    2. Detach the printer from the computer: take out the USB cable.
    3. Uninstall the software for the F380.
    4. Install the full feature software plus updates for the printer.
    5. Do not connect the printer until installation has finished or only when a message shows up, during installation, to power up the printer and connect the USB cable.
    Jun 21, 2010 | HP DeskJet F380 All-In-One Printer
    I have Windows Vista with an HP Deskjet F380 all in one. It will print but will not scan. I have downloaded from HP the drivers and all updates, but still nothing.
    From your description, it's hard to say why it won't scan....Does it start to scan, or is there no response from the scanner at all?
    Try resetting the machine, then try again. (instructions here) Make sure it is set up correctly and do not connect USB until prompted by software (see here).
    If that doesn't work, see this article and this article and make sure you have a good power source for your computer and printer. Also make sure you use a usb port on the back of the computer.
    Your home support page for HP is here,
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Jul 10, 2009 | HP DeskJet F380 All-In-One Printer
    Scanner could not be initialized on Deskjet 4180 all-in-one
    Most of the time I solve this problem by cleaning the scanner. You have to clean it real good. Take out the scanner bulbs and clean underneath the bulb sockets. You may not be able to do this. You may want to call a tech.
    Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    HP Deskjet F380 won't print
    i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
    try to clean manually the printer by using powerful air blower,repeatedly.
    Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
    HP Deskjet F380 - NOT SCANNING
    maybe this is one of those printers that need to be connected directly to the power mains, not a power strips..check on that first
    http://tinyurl.com/6qcpgy
    Jul 23, 2008 | HP DeskJet F380 All-In-One Printer
    HP DeskJet F380 All-In-One Printer Logo
    44 people viewed this question
    Ben Johnson
