Question about Dolphin Maytronics Advantage
Dolphin vacuum. Turn switch on and it turns about 2 times,stops for a few seconds, and then turns about 2 times. This goes on for 3 to 4 times then stops and does not turn again. What are some possibilities?
    President:
  • Dolphin Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Your problem could be in the power supply, cable or motor unit. The motor unit is the most likely problem. For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 06, 2010
Dolphin diagnostic motor replacement
May be the circuit board - There is an on-line group called Circuit Board Medics who can test and repair the board.
Jun 22, 2012 | Dolphin Maytronics Diagnostic Robot...
Tip
Your Dolphin pool cleaner wont start up...
A common problem, especially with 'newer' Maytronics Dolphin brand pool cleaners is that you put the unit in the pool, or even try to turn it on after a cleaning cycle while it is still in the pool, and to that point it has worked fine. You turn the power supply on and nothing happens. You turn it off and back on and still nothing. You leave it, even over night, same thing. What do you do?
While I cannot tell you why it does this (we have a theory but can not confirm it) what usually works is to follow these steps...
1) Unplug everything. Unplug the power supply from the outlet and the Dolphin from the power supply.
2) Let the whole thing sit a couple of minutes (we want to allow any capacitors to discharge).
3) Be sure the Dolphin is out of the water and sitting upside-down on a level surface (Tracks pointing skyward).
4) Reconnect the Dolphin to the power supply and the power supply to the outlet.
5) With the Dolphin still out of the water, perform a self-test. Simply turn on the Dolphin. Within about 15 seconds it should begin to move. The tracks will spin in both directions with and without the impeller motor running at the same time. It is not unusual for the tracks to rotate at different speeds during this test. The test will last for 30 - 45 seconds or so. If it goes on indefinitely, turn it off and contact us for further direction.
6) Assuming the unit has now worked to this point, you should be able to put it back in the water and it will return to normal operation from this point on.
If it still won't run; it runs a few moments and quits the self-test; or runs continuously, contact us thru the Dolphin service form along the bottom of our home page at www.arrowpools.net.
on Dec 16, 2009 | Dolphin Maytronics Diagnostic Robot...
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
My dolphin diagnostic cleaner for my below ground pool, just stopped after years. I went to turn it on yesterday and there is power to the power box as the light goes on, but the unit is not moving. I am...
If your unit has a fuse it will be on the back side of the power supply. If the light on the power supply switch is on, it will not be the fuse though.
Try turning the cleaner upside down on the deck and connect it as you otherwise would. Power it up and it should go through a self test process that takes about 40 seconds to complete. If it turns the tracks in both direction with and without the impeller turning, it is fine and will likley start working in the pool again.
If not, contact us through www.arrowpools.net and click on the FAQ and then Dolphin cleaner catagory. You can also use the Dolphin Serice button for information about sending it in for repair.
Jul 03, 2009 | Dolphin Maytronics Advantage
Nissan Installed throttle reprogram
Here is the way to do it without the nissan scan tool. Make sure to follow all steps and it it best if you use a watch with a second hand.
1. Perform "Accelerator Pedal Released Position Learning".
a. Make sure that accelerator pedal is fully released.
b. Turn ignition switch 'ON' and wait at least 2 seconds.
c. Turn ignition switch 'OFF' wait at least 10 seconds.
d. Turn ignition switch 'ON' and wait at least 2 seconds.
e. Turn ignition switch 'OFF' wait at least 10 seconds.
2. Perform "Throttle Valve Closed Position Learning" .
b. Turn ignition switch 'ON'.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound. 3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic 'PREPARATION' (previously mentioned) are in good order.
5. Turn ignition switch 'OFF' and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch 'ON' and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal. 8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL goes off.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
13. If idle speed and ignition timing are not within the specification, the result will be incomplete. In this case, more test needs to be done.
Jun 24, 2009 | 2004 Nissan Sentra
Dolphin Commander goes forward 2' then back 2' then stops.
The impeller motor is likely worn out. New motor units are expensive but less so than a whole new unit. You can send it to us in Michigan at www.arrowmotor.net or find a closer service center using www.maytronicsus.com Good luck.
Jun 14, 2009 | Smart Pool Inc Dolphin Diagnostic...
How can I stop airbag warning light flashing continuously on my Nissan Tiida
Try this:
5. If “AIR BAG” warning lamp operates as [as I said before], turn ignition switch “OFF” to reset from Diagnosis mode
1. Turn ignition switch “ON”.
2. After “AIR BAG” warning lamp lights for 7 seconds, [i.e. when it stops running solid and starts flashing] turn ignition switch “OFF” within 1 second. [DO NOT SWITCH IT TO LOCK, SWITCH IT TO ACC]
3. Wait more than 3 seconds.
4. Repeat steps 1 to 3 two times. (Perform 3 times in total.)
5. Turn ignition switch “ON”.
SRS is now in Diagnosis mode.
Try it a few times. If you can't get it to work, have someone else try. If you STILL can't get it to work, check your battery voltage. It might be low.
In diagnosis mode, you're going to hope the light flashes slowly. 2 seconds off, 3 seconds on, and repeats. If your light does this, this means that the computer detected a previous error that hasn't been erased. This is good.
to User mode and to erase the memory of the malfunction.
6. Turn ignition switch “ON”. “AIR BAG” warning lamp operates in
User mode. [it should stay on for 7 seconds, then go off, like normal.]
May 17, 2009 | 2006 Nissan Titan
Stops while driving
this is usually due to a dirty throttle body. just beware if you do try to clean it you will need to preform the idle relearn procedure. this does work, ive done it personally.
A. Accelerator Pedal Release Position Learning Procedure.
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds (how would you know if you get it right?)
B. Throttle Valve Closed Position Learning
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound (i never get this right because i never heard anything)
C. Idle Air Volume Learning (Throttle Position Learning)
It's best to time with a watch/clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
11 Wait 20 seconds
12Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications. (this is fine because SES light lets you know if you did it right the way it blinks)
Oct 25, 2008 | 2005 Infiniti G35
Dolphin Maytronics  Advantage Logo
148 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Marvin
Marvin
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
