Question about Rowenta DX6700 Iron
Dropped iron and now leaks when water is put in it
3 Suggested Answers
DiYerTech
  • 70 Answers
SOURCE: The iron will not produce steam.
There are several thermal sensors around the tank, did you make sure they were not damaged or bent...they are "bi-metallic" strips, meaning they are two disimilar pieces designed to have different thermal expansion rates so at certain temp they separate (open) or move together (close) telling the control logic board to enable heater. Do make sure you did not bend them or over torque them when reattaching to their respective attachment points.
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Posted on Jun 06, 2010
heatman101
  • 43501 Answers
SOURCE: iron leaks water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
Why does it leak?
You answered you own question. She dropped the iron. That broke the water tank. Time for a new iron. It happens.
Nov 28, 2015 | Irons
Why does water leak out of bottom of iron base unit when ironing .could it be the filter unit ?
Probably not the filter.
If it is a new iron and the drops of water are excessive I would suspect it is faulty.
If the iron is well-used I would suspect it has a scale problem where localised scale build up is preventing some of the water from closely contacting the heated metal and turning to steam. This could be particularly true if you live in a hard water area.
Steam irons originally soon caused problems unless distilled or de-ionised water was used. It is reckoned modern irons can use tap water but hard water can still cause trouble.
A descaler additive might help but I haven't had good results in the past...
Oct 19, 2015 | Irons
How to fix a leaking water out where you put the water in the iron
Strip the whole iron and inspect that water bottle you will see how you can close it or you can use it without putting water ucan wet the cloth first
Sep 12, 2014 | Conair Irons
My rowenta progressive iron is leaking dark black water from where the cord retracts. What is causing this. Where is black water coming from?
The mountains of Mt. Fuji have blessed you. Just kidding, have you ever dropped this iron? Mold may be growing where there is a leak in the holding tank. Water and electricity do not mix, time for a new unit.
Jun 18, 2014 | Irons
Iron leaks. have cleaned it several times. still leaks. iron has not been dropped or damaged.
heatman101
Aug 07, 2009 | Black & Decker Prestige X805 Iron
Leaky water from sole plate
Open up iron, see if hose connected to tank came off. If you dropped iron a few to many times you could have cracked tank. Open up and you will see problem.
Jul 17, 2009 | Irons
Iron leaks water
heatman101
Mar 11, 2009 | Rowenta DZ9080 Iron with Auto Shut-off
I need some help
heatman101
Jan 21, 2009 | Euro-Pro G6118 Iron
Water pouring out of my iron
heatman101
Aug 26, 2008 | Rowenta Powerglide DM273 Iron
LEAKING IRON
This was happening with mine - leaving trails of water behind as well when I ironed. I took it all apart (figured it was already broken, what could I do worse?) I discovered that there is a rubber gasket around the hole that lets water move from the reservoir to the heating plate. The two surfaces (reservoir and plate) are held together by screws, which compresses and seals the gasket. The bottom surface of the reservoir section had been cracked (due to a drop on the cement floor, probably, and the two surfaces could no longer fit tightly together, the crack allowed it to flex, and water leak out. In other word, once it's leaking like that, it's time for a new iron. Sorry I can't offer a fix, but at least a explanation!
Jun 25, 2008 | Rival IR600 Iron
Rowenta DX6700 Iron Logo
88 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
