SOURCE: Technics SU-G91 OVERLOAD PROBLEM
OVERLOAD means that input signal level is too high. Can you be more specific? From which source you play music when OVERLOAD icon appears?
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
SOURCE: technics stereo integrated amplifier su-g91
hello ive got a diffrent problem ive got a technics hifi and when u put it onto aux it says txe-rvc and cd is dc its all the wrong way around what can i do thanks
SOURCE: Technics su-Z750 Intergrated Amplifier stays in Standby
HI...
This happens when one or more components in the power amplifier section has failed.
The protect circuit keeps large DC voltages off the speakers.
The only thing you can check for before finding a tech is that the speakers are firmly connected at both ends. If they are ok, you need a tech
PLease rate my help if this helps
