Question about Pioneer GM-5000T Car Audio Amplifier
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
  • 22 Answers
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Posted on Sep 10, 2010
    I have 2 12" Pioneer TS-W3003D4 subs and I wanted to know can a Pioneer GM-D8500M run them?
    pretty much any amplifier can run any sub, so the question is not weather or not the amp can run them, it is how well the amp can run them. Those Pioneer subs are dual VC models and are rated at 600 watts RMS. You have two, so that would be about 1200 watts of RMS power you will need in order to power the subs correctly and to optimum efficiency. The amplifier model you have is rated at 600 watts RMS for a single channel at the lowest stable impendence. That power coming from the amp will be split two ways between the subs and divide the power to each speaker. So each speaker will be receiving 300 watts of power. So in short yes, your amp will power those subs, but they will only be operating at half their rated power. Your amp will be running at maximum power so it might get a little warm after a while. make sure you wire it correctly and keep the amp well ventilated if you decide to push it that hard. if you need help on how to wire them search the web for wiring options by typing into Google " how to wire two dual voice coil subs into amp". There you will find plenty of illustrations to help you decide.
    Aug 25, 2015 | Pioneer Car Audio & Video
    Brand new pioneer 820 watt amp worked for about ten minutes, now the speaker output light flashes on and off
    You didn,t have the sub wire up properly, End fried the output transisters in the amp. Or it was not set (Properly)
    Nov 05, 2012 | Pioneer Car Audio & Video
    PYLE PT2001X 3300 Watt Professional DJ Power.just had question about running this amp in bridged mode 4 ohms, here's some amp info 3300 watts total power bridged in 1 ch only.1650 each ch in stereo mode...
    In bridge mode the minimum load will be 8 Ohm.
    If you are using 4 Ohm speakers, it will mean you will give each side of the amplifier a 2 Ohm load.
    Thats to much for this model.
    Kind regards,
    Gerard
    May 13, 2010 | Pyle PT-2000 Amplifier
    What size amp do i need to run 4 1000 watt pyle 10's bridged
    well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
    Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
    PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
    depending on how many channels the amp is, you may not be able to hook everything up to it.
    usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
    To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
    If you have a mono amp its only for subs.
    If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
    you need a channel per speaker basically.
    Dec 15, 2009 | Pioneer DEH-P2000 CD Player
    What kind amp should be use for ts-w307d2 subwoofer speaker?
    Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
    Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
    Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
    I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
    Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
    What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
    Hello oran1891,
    OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
    Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
    The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
    Hope this helps.
    Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
    Speakers
    400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
    Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
    Speakers
    Hi Trim God,
    I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
    Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
    Pioneer GM-5000T Car Audio Amplifier Logo
    148 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Marvin
    Marvin
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
