Question about Motorola Mobility HS850 Consumer Headset
I am trying to pair my hs850 to my nokia n95 8gb
When i type in the 4 0000's passkey it fails to connect. why?
    Guru:
  • 160 Answers
To emu144,and others if passcode wont work completely remove all bluetooth connections from phone and try repairing make sure headset has a good charge
Posted on May 10, 2008
I have tried everything . My Motorola Hs850 will not connect. It keeps indicating that the connection failed
Firstly, make sure you have enabled Bluetooth on your phone or whatever device your using the headset with. The default setting off, so go into your phones set menu and enabled Bluetooth.
You'll then need to 'pair' the headset and phone.
1. Ensure the headset is turned off (indicator light not blinking).
2. Press and hold the Call E button for 4 or 5 seconds. The indicator light will initially flash, but continue to hold down the button until the indicator light is steadily lit.
If the indicator light is flashing or not steadily lit when releasing the button, repeat both steps 1 and 2. Hold the Call E button for 4 or 5 seconds.
3. Enable Bluetooth on your phone and get to 'search for devices' it should find the headset.
4. Select Motorola HS850
Select OK or Yes to pair your headset with your phone. Enter the passkey: 0000 Select OK. When your headset successfully pairs with your phone, the indicator light changes from steadily lit to flashing.
Hope this helps. Oh and make sure your phone actually supports the headset!
Jun 13, 2011 | Motorola Mobility HS850 Consumer Headset
Motorola hs850 bluetooth headset won't pair with Blackberry Curve
try to delete it out of ur phone all the way and then try to pair it again
Dec 15, 2008 | Motorola Mobility HS850 Consumer Headset
I've lost my pairing code how can I get another on, or is there a
From the Motorola Website:
The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
This should work for you, but if it doesn't you'll to contact Motorola
Dec 05, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
Nov 25, 2008 | Motorola Mobility HS850 Consumer Headset
HS850
Good Day,
Passcode is "0000"
Hope this helps
Jul 02, 2008 | Motorola Mobility HS850 Consumer Headset
How do i connect motorola hs850 with lgcu720 (shine)
1. With the headset’s boom closed,press and hold the Multifunction
Button E until the headset indicator turns on (about 3 seconds).
2. Release the button, then open the headset boom.
3. The headset indicator remains on.
4. Perform a device discovery from the phone.
5. Select the Motorola HS850 from the discovered devices list and confirm following the on screen prompts.
6. When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
The device ID is now stored in the phone’s memory.
Pairing is successful when the headset indicator flashes 10 times
rapidly.
Hope this helps
- Ted G.
Jun 25, 2008 | Motorola Mobility HS850 Consumer Headset
Trying to pair motorola n136 with my sprint rumors phone
Found this when trying to pair mine:
I had the same problem - what I thought was the unit number was not - it is actually HS850. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/...
Basically, hold down the call button until it lights up (steady -not blinking), open the boom, and search for devices in your phone. When it finds it, the passkey is 0000.
Jun 21, 2008 | Motorola Mobility HS850 Consumer Headset
My bluetooth passkey
Passkey 0000 worked for pairing my Motorola HS850 and my Blackberry 8800. Thanks!
Dec 12, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
81 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
