Question about Braun M880 280 Watts Hand Mixer
BRAUN GMBH MODEL NO.-D421.51U1 SPEED MODULE in power industry
Braun 4169 user manual
i could not find a user manual but follow this link to a schematic of the machine and its parts numbers hope this helps you
http://www.1800parts.com/images/1800Parts/English/products/standard/4169-Schematic.pdf
Sep 17, 2012 | Braun Hand Held 120 W Mixer Model 4169 In...
I can attach the immersion blender attachment but it does not turn on. The machine works fine with the mini-chopper attachment or the beaters. How can I fix this?
Hi
Make sure you use the pulse function of the power switch. Only this position (forward, away from you) will activate the immersion blender, and then at full speed only.
Feb 09, 2011 | Braun M880 MultiMix Hand Mixer
Braun multimix won't run on 1st and 2nd speeds--only 3rd speed.
Hi.
This problem has been covered already on this link. Please leave a comment if further assistance is required and I will do my best.
Dec 10, 2010 | Braun M880 MultiMix Hand Mixer
Braun MultiMix 880 became a one speed. Is a replacement switch available?
Apparently the switch is very easily available, unknown for what reason. In Europe they say it is not available at all anymore, which I find strange.
However!
Dissasemble, by removeing base plate and screw underneath curved retainer plstic clip in the front. Then gently pry apart with blunt, thin object to split the two halves. Remember to unplug the power cord first. Check the circuit board for cracks, or burnt components. Then suspect the triac/tyristor. Desolder it and test it with a multimeter. (google "test triac multimeter"). Then note the code on the front of the triac, and search for a supplier of electronic parts to get hold of a new one and solder it back on. Note the orientation of the pins, and reattach heatsink if fitted. (Euro version have non.)The triac often looks like a flat design transistor and have a code/part nr that may look like; TCI 226 N, as on my European 230v version. Electronic components suppliers also have interchangeability lists for different manufacturers and use cross reference lists. Should only costs a few dollars or so. Triacs tend to stay fully open when failed, causing full speed in any mode. It is worth a shot.
Nov 22, 2010 | Braun M880 MultiMix Hand Mixer
Braun multimixer m880 the motor has finally died,
See
http://www.smallappliance.com/product.asp?pid=5623&cur=USD&sid=18956&mid=5&gid=18978&prdCls=P&PartsPaNu=1&shopBy=Brand
(2 pages)
And you will find spare parts online for your braun which i believe is model nr 4642 (se baseplate).
You may also use braun's own spare parts finder at:
http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=pf&frmTyp=s&grp=0&s=4642&subgrp=&des=&sgrp=s&sString=4642'HH'HH06'H'MultiMix&seite=2
But you will have to contact one of the authorised service partners to buy.
Oct 14, 2010 | Braun M880 MultiMix Hand Mixer
I need a chopper attachment for my Braun M880 multimix hand mixer
See
(2 pages)
For a chopper attachment; you may need bowl plus rotating blade.
Sep 01, 2010 | Braun M880 MultiMix Hand Mixer
Need Spare Whisks
See
(2 pages)
Aug 07, 2010 | Braun M880 MultiMix Hand Mixer
Bottom Slide Cover (Part 2a in the manual)
See the description for the speed problem and repositioning of the slidere at this link. The slider should snap back in place easily if everything is ok. The slider also operates a switch inside the mixer. This switch is intended to only allow you to run on full power when using the hand blender. You may need to open up the mixer to check this switch is not stuck in the activated position permanently. Otherwise consider the description of the speed problem in the link.
Jun 17, 2007 | Braun M880 MultiMix Hand Mixer
Braun M880 280 Watts Hand Mixer Logo
404 people viewed this question
Top Braun Food Mixers Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Are you a Braun Food Mixer Expert? Answer questions, earn points and help others
