Question about Moyer Diebel 401HT Dishwasher
Dishwasher works for 15 seconds then it stops, and indicator says cycle is finished. when i try it again it only fills with water and nothing happens. i'm wondering if it's motor problem or if there's something wrong with the pump. if it's motor, do you know any place online that i can order it? thank you.
    Problem Solver:
  • 40 Answers
The pump and motor comes as one unit. Motor does not come seperate. Pump parts can be sold seperately
Posted on Feb 13, 2014
funkyjacob
  • 76 Answers
SOURCE: cycle doesn't finish
Its the timer you need a new one they arent hard to get just ring up your local apliance man and tell him (or her) you model number and brand and he will order it and fit it for you
Posted on Jun 22, 2008
  • 13 Answers
SOURCE: Kenmore dishwasher not draining when finished full cleaning cycle
sounds like a cycle timer problem. Look for a loose wire on the cycle timer. If yours is a digital timer, it is a board issue. Sorry.
Posted on Aug 20, 2008
rickzilla
  • 706 Answers
SOURCE: LG LD-14AW3 Dishwasher leaking after cycle
Sounds like you've diagnosed the solution on your own.. Most of the inlet valves are spring loaded so that if power is removed or disabled.. it defaults to a closed state and doesn't allow water int the wash basin. To open, they need to be energized by the control system so you may have one of two issues.. a faulty inlet valve that doesn't spring closed when it is not energized or a controller that is comanding that valve to open ( less likely of the two) For a quick test.. make sure the DW is dry inside and open the door. wait and watch for water to enter the basin.. If it does begin to fill up.. your inlet valve could be the root of your problem.. It is also possible that you are back-siphoning waste water in from the drain system. If the water looks dirty then that is more than likely the problem so you may have a clogged pump, kinked drain hose or your drain system itself is not draining as fast as the DW pump forces the water out.
You should routinely clean the pump filter so that the pump can remove all the wash water without having to draw it thru food debris caught in the filter.. Hope someof these ideas will help you solve your problem..
Posted on Sep 01, 2008
  • 1075 Answers
SOURCE: Dishwasher filled with water even though cycle was finished.
the same problem accures with some types of washing machines,when you turn on the machine the control switch sends a signal to a valve on the mains water supply inside the back of your machine telling it to open the problem accours if you live in an area that has hard water because lime scale builds up in this valve so when you switch it off the valve is in the open position because of a lime scale build up, i would say it needs an new valve.adrian
Posted on Feb 16, 2009
SOURCE: Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
Posted on May 18, 2009
Indicator lamp keeps on flashing and my dishwasher does not take any wash cycle. did try the two second hold of start button and selecting new wash cycle.
Usually this is a simple fix. It sounds like you ran out of rinse aid. Fill the dishwasher with cascade or finish rinse agent into the dispenser. Try to start a wash it should work.
Feb 05, 2018 | Dishwashers
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Asko Dishwasher D3122 fills with water and stops
if the heating element has failed the water temperature will not reach the trigering threshold to allow the timer to advance to the next program step good luck !
Dec 26, 2013 | Asko Dishwashers
5 year old dishwasher.Press START button,dishwashing cycle kicks in for a few seconds then stops.A few seconds wait and it starts again, and on and on.It finally works its way to the full cycle.
The dishwasher is taking too long to fill with water...
Here is a tip that will help you to find out whywater will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
May 24, 2011 | Whirlpool Dishwashers
My Kenmore Elite dishwasher just hums when we start it.Its not starting and no water is filling up
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Aug 09, 2010 | Kenmore Dishwashers
I have a Maytag Quiet Series 100 dishwasher. There is an icon with a "3" in it just to the left of "heat dry." I just noticed this "3" light is on and the dishwasher won't start when I push the...
The "3" means hold for 3 seconds to child proof it. When it's on, none of the functions work. When you hold it again for 3 seconds, it turns off and your buttons will work again.
Aug 06, 2010 | Dishwashers
Dishwasher starts to work but after 30 seconds stops and two lights start flashing on pannel
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.Service manual below, if the above doesn't help. http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Jun 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
The lights come on but it doesnt fill with water. it doesnt make any noise as though it is trying to fill up
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/a045b97f9e505696852574ce0049f265?OpenDocument
Hi above please find your service and repair manual.If the fix below doesn't work, then work through the service manual troubleshooting steps and you will soon zero in on the problem.
Now this fix below may or may not fix your DW, however it works many many times, so may well be worth a go to start with.
Jun 18, 2010 | Whirlpool 24 in. ADG7540 Built-in...
F6 Not Heating Alarm
The water is hot because you are filling the dishwasher with hot water... but the heating element is bad and it is not keeping the water as hot as it needs to be...
Check out this tip....
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
heatman101
Apr 22, 2010 | Sunbeam SNB652SIAS Dishwasher
My dishwasher fills, but won't start running. it just sits full of water and just hums.
Apr 14, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
Dishwashers Logo
75 people viewed this question
Top Moyer Diebel Dishwashers Experts
Marvin
Marvin
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
