Question about Philips HTS3450 System
My subwoofer power light is dimming
I have a low-connection AV cable running into the subwoofer..in about 7 secs the light gets verry dim. Plus there isn't no sound being produced!!
  • Melloman Jun 09, 2008
    My product is doing the same thing. The sub-woofer light is getting dim and plus there's no sound coming out.
Short circuit, Power module can be broken. Tell me how is working without any connection, just power it.
Posted on Apr 27, 2008
Driver side headlight goes dim on high beam while passenger side is bright
bad connection or bad earth check all connection or bulb
Jan 24, 2016 | Cars & Trucks
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
https://answers.yahoo.com/question/index?qid...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from answers.yahoo.com
Dimming Microwave Light - Breville Support
brevilleusasupport.com/bmo734xl/dimming-microwave-light/
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
Dec 21, 2015 | Microwave Ovens
Low beams go off when high beams are on
what car, what year,? what model (wrangler?) im clueless
bulbs get weak with age
the glass in bulb (looks like silver paint)
this is normal for extreme usage.
replace the bulbs if dim. both.
if the car has covers in front of bulbs (not my 02 wrangler)
but newer cars have this crappy plastic in front,
it can be cloudy, there is a nice kit that fixes it (labor) at walfart. ask.
dim lites?
1 dim bulbs
2 cloudy lenses.
3: bad wire, bad grounds and bad connectors to lamps.
4: wiring hacked by kids wanting HID bs.
5: wrong bulbs, kids again.
6: corroded fuses, (12v at lamp do you have)?
7: bad combo switch or its ground is bad.
if you have 12volts across the dim lamp, you can skip 3 to 7 fails.
see your FSM for how they work. and wiring.
does your car have DRL? daylight running light option or in CANADA?
that be more heart ache.
and my jeep the highs and lows are never on at the same time.
the combo switch selects one or the other.
what it does in flash mode, not sure. need car year. and name.
Dec 16, 2013 | Jeep Cars & Trucks
Interior lights and exterior lights are dim, along with heater fan running slow, when first starting car. After a few seconds, lights brighten and fan speeds up. What is it?
For some reason the alternator output is very low when the lights are dim. Something happens to bring output up to normal when they get bright.
Slipping belt, or an electrical problem.
Jan 27, 2013 | 1996 Pontiac Grand Am
Trouble shoot a 2007 honda crv starter
Take the starter off for testing. If the lights were normally bright, and went dim when key was in cranking position, it means the start circuit is working-battery power is going to the starter, but it won't do anything. The starter motor is probably bad.
Good luck.
Jul 14, 2012 | 2007 Honda CR-V
When i turn on my headlights the left side gets dim and the running lights all go dim but the right head light and running light are bright. the dash lights also goes out on just the head light setting. If...
it sounds like you have a bad connection on the left headlight either the earth or the power wire,check the connector on the headlight bulb plus all the other wiring & connector plugs.....hope this helps.....cheers.
Jul 01, 2011 | 1993 Subaru Loyale
1990 buick no start turn key dash lights go out and all is dead
When you say "turn key dash lights go out and all is dead", do the lights come back on when you turn the key back to "off"?
With key off, try turning on your headlights- are they bright?
Flip to high beams-do they get brighter?
**If lights get dim while trying this, it's the battery-(dead/needs charged or replaced-which may have been caused by a bad alternator).
Leave lights on, now turn your ignition switch to "on"-do the lights get dim or go out?
Try and start the car-anything change?
If the lights were fine until you tried to start the car, more than likely your battery terminals need cleaning/tightening.
The lights should at least get dim when you try and start the car but only while the starter turns over: when the engine is running your lights (as well as all your other electrics) are powered by the alternator.
If you do all this and lights are okay all through this procedure, your problem is probably in your starter circuit. (Starter relay, ignition/key switch)
Hope this helps.
Dec 16, 2009 | 1990 Buick Riviera
LED lights dim on HT720
Check the subwoofer for a blown fuse. I hope this helps. ~ Bruce :)
Aug 31, 2009 | Audio Players & Recorders
Subwoofers
If the light on the amp is dimming when the bass hits it's usually a power related problem. It sounds to be that you don't have enough power going to the amp to drive the sub. It should stop if you reduce the volume at which you are playing the music. Yes?
How to solve this is to, increase the size of your power cables, add a power capacitor if needed & change the car battery to a higher capacity one.
The other option a little more professional, would be to fit a split charge system & a secondary battery to the boot/trunk of your car just to run your stereo system, with a power capacitor too. This will provide all the juice that your system requires so you can bang your head as long as you want :P
Sep 24, 2007 | Car Audio & Video
Philips HTS3450 System Logo
108 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
