Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Side by side freezer not working? I hear fans but it's not cooling or making ice?
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dfgf
Posted on Sep 30, 2010
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The bottom freezer of my Kenmore Refrigerator works fine but the top refrigerator compartment no longer cools? Thanks
All the cooling happens in the freezer.The refer section relys on a fan to blow cool air into it.When you open the freezer you should hear a fan running.If you hear the fan running, close the freezer door and open the refer door. Look for the vent/area where the air comes in.Put your hand in front of it.If little or no air is coming out it could be a sign of an icing/defrost problem restricting the air to the refer section.
It will take a tech with the right tools to find the exact problem.
If the fan is not running you will have to unplug the unit and remove the back of the freezer section from the inside and make sure ice is not keeping it from turning.If it is free of ice then replace the fan motor.
Mar 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
Mod# GS6SHEXNLOO Ser# GF827090B Strip between side by side doors is hot to touch, not luke warm. Fan in back is working but not cooling.
The fan which cools the compressor ? You cannot hear the fan that cools the compressor . Have to visually look , If you hear a fan , it has to be the freezer fan you are hearing .Remove the rear panel behind refrig to see compressor fan .
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
This fridge turns on, the freezer no longer will make ice
Okay, let do this.
1, Check the freezer if you can hear and fan motor or air blowing?
2, check the condenser, amke sure no trash or dirt block the air circulating, located lower kick guard panel, pull out the grill and you can see it.if you can't hear anythings. then you need a new circulation fan motor.
If the above are check and it still not work, you may have lack of refrigerant.
Jun 09, 2009 | GE GSS25LGM Side by Side Refrigerator
Side by sise refrid freezer top is not cooloing on freezer side warm on refergerator side
suspect fan is not working - can you hear fan?
if not, chances are fan is jammed with ice build up. take back panel off inside freezer and if there is ice build up, melt off with a hairdryer. also check for continuity thro fan and make sure it rotates freely
Oct 09, 2008 | Whirlpool Refrigerators
Not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Aug 28, 2008 | GE GSS20IEP Side by Side Refrigerator
Frigidaire does not work (freezer and cool area)
what can u hear. u should hear fan in freezer. fan in back. is compressor running. is ice in freezer on back wall. are both sides not cooling. post more info to go by
Jul 02, 2008 | Frigidaire FRS26RLECS Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
