Question about LG GH22NP20 22x Internal DVDRW Retail Kit DVD±RW Dual Layer Burner
Hi am new in FixYa seems I cant find the same solution for my problem. I am asking help for my promlem. I have LG GH22 it works fine before but suddenly it can't read anything. When I try to open the Drive. It's blank though I am inserting disk with content. Please I'm totally lost trying any solution.
  • 415 Answers
Try getting a DRY cotton bud and gently wipe the laser lens (while off) and try a disk.
let me know how it goes.
Posted on Aug 06, 2010
I have a problem with my LG Super Multi DVD Rewriter GH22. When I try to burn a disc, the writing process will start (mostly), but at some point the drive will get stuck so that the writing process never...
The issue seems not related to the LG Burners, possible the disc in which you are trying to burn may be issue.
Can you try with the different brand disk.
Oct 12, 2010 | LG Computers & Internet
Can I put internal LG GH22 rewriter inside external GSA-E60N
First, open the external casing.
You'll find an "internal" CD/DVD drive, connected to an adapter, and the adapter connects to the USB cable.
Now, look at the adapter -- it could be a "parallel-ATA" interface, or it could be a "SATA" interface. The new CD/DVD drive will have to have the same connectors (data and power) as the adapter.
You might have to exchange the SATA device for a Parallel-ATA device.
If you have a parallel-ATA CD/DVD drive, look at the back of it.
There is a tiny jumper, and a few labelled settings:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper to the 'MA' setting, so that the USB-adapter will recognize the CD/DVD drive.
Connect the drive to the adapter.
Close the case.
You're good to go!
Jul 22, 2010 | LG Dvd Rewriter Gsa-e60n 20x Ext Black...
LG GH22 LS50 (Sata Dvd Writer) Will not write dvd discs
What software do u use to write DVDs on both PCs...
if they are different then that may be the issue....
dont spoil the DVDs....
try DVD RW disks...that way you can erase them later...
i too have the same DVD writer, not had any issue in either XP or Win7....i have dual boot and have made many movie DVDs using both OS...i use Nero and Power2Go of LG(the install disk that came with the LG DVD writer has this great software...."LG Power tool")
try this tool...it should work...
the inbuilt DVD creator in Win7 has some issues with DVD creation....due to non compatibility of graphics card and display drivers (WDDM)....+ you may not have the correct codec required to burn DVDs.....
get the FFDSHOW codec from google.... and install it...shutdown and restart and then try...
let me have a feedback pls...
reg
May 04, 2010 | LG GH22LS50 DVD-RAM Burner
LG GH22 is not working
The most common issues are cable related. If the eject button on the front works but the computer doesn't see the drive, check the data cable. Make sure the cable is fully seated at the motherboard and is correctly oriented and connected to the drive. (Check the orientation first; it is easy to get upside down.) Since this is an IDE drive, you may also have to check the jumpers are at cable select.
If the eject button doesn't work, then you don't have power. Try a different power connector.
If you have enough power to eject and see the drive, then check your drivers and software. (A failing power supply or one that just doesn't have enough power for your system under load are also possible issues for write problems.)
Dec 15, 2009 | LG GH22NP20 22x Internal DVDRW Retail Kit...
What is happening is i am trying to go online and it is a brand new game and the xbox is asking me to clean the disc every time. I have tried another game and it works fine can you help me my moden is on...
Take the DVD disk to Hastings. Tell them to clean it, it will cost you about 3.00. Bring it back. If it does not work, you have a defective disk, take it back and exchange it.
Hope this helps
Frank
Nov 15, 2009 | Microsoft Xbox 360 Elite Console
Dageezer sdays the LG GH22 dvd writer is a sata
You can refer to the following user manual , for the drive installation
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1244168
Thanks for using Fixya
proton
Nov 08, 2009 | Dell Dimension 3100 PC Desktop
I hav ejust purchased a new lg gh22 dvd writer. It is working fine in operating system like windows xp and ubuntu. The bios also recognizes the drive. But when i insert a bootable cd/dvd of ubuntu windows...
hi,
Is the hard disk drive is in secondary slave? If yes, change it to master and your dvd is into slave. Refer to the jumper settings at the back on the drive. If not work, your bootable disk may defective. Try other a botable disk.
Best regards,
geloaa
Oct 06, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
I have accidently enlarged my screen on my mobile while viewing facebook and google.. i cannot seem to get it back to normal size..can anyone help me? I have only got this Lg KU990 mobile so have not...
hi,
when dialling this, its 3845#*990 then press dial, please be careful when doing this as it comes up with a new screen straight away.
back up your contacts and details in phone memory
thank you for using fixya,rate my answer
vijay
Sep 30, 2009 | LG KU990 Viewty
LG GH22 dvd writer - not reading
I had the same problem with the GH22 Internal drive on vista. Assuming this is the only cd drive you have, just go to the device manager and remove/uninstall anything under "DVD/CD Rom Drives" then restart. It should get picked up and recognized properly. It took a couple of restarts to work. For refrence, I only have the LG GH22NP20 installed, what appears in device manager are 2 items... (1)HL-DT-ST DVD-RAM GH22NP20 SCSI CdRom Device... (2) KU1051Q EAG855E SCSI CdRom Device... Incase you have multiple cd drives, this should help tell em appart. Enjoy. IDK399
Jan 20, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
LG GH22NP20 22x Internal DVDRW Retail Kit DVD±RW Dual Layer Burner Logo
132 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
