Question about Mitsubishi MSH09TW Air Conditioner
ASW-H12A4/EL water is comming out - inside. How can I reach the tube from inside and clean it?
My machine is a SANYO ASW F101AT when I start the machine the water over fills and shows an ER. there must be level switch some where, How do I fix it
there is a water level switch and it is controlled by a small tube from the tub to the switch
as the water rises in the tub , the pressure in the tube over comes a spring tension in the switch that you set by wash load level
when that setting is overcome the switch powers the solenoid for the water inlet and shuts it off at the same time starting the wash cycle
so you have 2 possible problems
i--- level switch
or
most likely a problem water control solenoid or diaphragm in the solenoid
the fix for the solenoid is a new one
check the tube to the switch or check the switch
do that bu setting low water level and listening for a solenoid operation for the water
Oct 27, 2016 | Washing Machines
My aircondition shows f6 error code starts outdor unit for few seconds and stops. Vox asw-h12a4/qb
Hi Marija, F6 error code is....I hope this helps.................CHEERS..
1?Check whether the resistance of sensor is normal, otherwise replace it.
2?Check whether the sensor wire is short circuit or open circuit, and whether the plug is well contacted, whether there is welding off or rosin joint on the electric control board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components or integrated circuit is damaged, the electric control board should be replaced.
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
May 08, 2016 | Heating & Cooling
How can I fix a faulty vale water vale working incorrect
the pressure activated switch is turned on to control a shutoff valve when the pressure in the clear tube reaches a certain level. If the tube is blocked, it will not get the light pressure on the air trapped by the column of water. Boyle s law P1V1=P2V2,
so replace (or clean out) tube with the same ID tube or the volume inside will not be correct for the rising column of water to activate the pressure switch.
Nov 09, 2014 | Washing Machines
Fujita remote control code for air conditioner model ASW-H12A4/HS
06,03,09,01 are the codes to check. If you wish to get more, check these links. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Selecting the view option, either to Mosaic / Timeslide, can be selected by the dropdown list, at the top left of the display window, it will make surf easy.
Oct 09, 2013 | GE JASRM24912 Remote Control
Lint inside that I cannot reach to clean out.
A lot of appliance parts and repair places are selling a long tube that you attach to your vacuum cleaner hose to reach down inside the tight places to clean out the lint
Jan 16, 2011 | Maytag Dryers
We have just installed our 1.5kw split system model no: ASW-H12A4/SQCR1DIAU - error message comes up as E5
E5 Outdoor activation of compressor over heatprotection or motor lock
or E5Communication error between outdoor and indoor.
Please check input of out door unit and contacor coil energized. if no power input correct it. If no power in contator coil, mat be the problem PcB thermostat command. Check your setting is 23 dgree and less than that and also mode in "Heat".
Dec 16, 2010 | Heating & Cooling
Air condition homemaker model hmasw-h12a4/ea-2 code error 3
homemaker H12A4/EA-2,dripping moisture from internal unit.I have cleaned drain pipe from unit,but don`t know where to go inside unit to find drain hole where it must be clogged. Do you have a diagram?
Jan 13, 2010 | Heating & Cooling
Amana Fridge: Internal water leak with Amana TJ18KW.
good morning
your freezer cabinet need to get all out also the ice machine(if you got one),and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
Errror code LF
If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed. This will be an issue that concerns the pressure switch. Follow the procedure below to address this issue further.
The water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
Nov 11, 2009 | Washing Machines
Mitsubishi MSH09TW Air Conditioner Logo
91 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
