Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
I have lg dishwasher and the soap dispenser does not work why is this happening or what would cause this problem
SOURCE: Dishwasher
detergent dispenser solenoid
Posted on May 13, 2007
SOURCE: Dishsoap stays in soap dispenser
Same thing happened to us. We noticed that it happened if the soap was left sitting before starting the washer. Since then, we immediately start the washer after putting soap in it and the problem appears to have gone away.
So much for the delayed start features, but at least the soap doesn't stick anymore.
good luck!
Posted on Jan 03, 2008
aborcass
  • 2651 Answers
SOURCE: Build up in dishwasher
powder works best in d/w. breaks down better in hot water application.
Posted on Oct 26, 2008
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
  • 126 Answers
SOURCE: Whirlpool Gold Quiet Partner IV issue with soap dispenser
I'd check the spray arms it may be there is not enough water or the wataer is not getting where it needs to be to disperse the soap. that is where I'd start.
Posted on Jan 16, 2009
The soap dispenser door will not open during the washing cycle. What could be my problem? I have a Lg dishwasher model #ldf7561st
If you don't want to disassemble the dispenser to replace a part, you can replace the entire dispenser. Additionally, if the dispenser isn't working and the entire dispenser is worn out, replace the dispenser.
Sep 26, 2015 | LG Dishwashers
Our LG dishwasher is not dispensing detergent like it's supposed to. we checked the bottom and the sprayers for any debri/food particles, but it was all clean. Could there be an issue with the dispenser...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Apr 25, 2011 | LG LDS4821 24 in. Built-in Dishwasher
Soap tablet not dispensing happens every 2nd or
heatman101
Jan 05, 2011 | Bosch 24 in. SGS43E08 Exxcel Built-in...
Soap does not dispense, door is open but alot of soap is left behid
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 01, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
SOAP dispenser does not open
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 19, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
LDF6920 soap will not come out of dispenser
heatman101
Sep 18, 2010 | LG LDF6920 24 in. Built-in Dishwasher
Soap does not come out od dispenser
heatman101
Sep 18, 2010 | LG 24 in. LDF 7811 Stainless Steel...
My dishwasher appears to work... water runs and cycle completes, but the dishwashing pellets will not disburse from the compartment. Any suggestions.
Hi there ...this problem is usually caused by a failed solenoid on soap disenser....usually requires dispenser replacement...however this problem .can also be caused by a faulty programmer....usually allied to no heat
regards Sir Galahad
Aug 12, 2009 | LG 24" Built-In Dishwasher - Black
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
SOAP DISPEN
is the machine heating ok?, if so then the dispenser and or the electronic control board is most likely faulty.
if the machine is still in warranty call your lg service agent and when the tech is on site, request that he change both the dispenser assembly and the control board.
if you are not over filling with powder then using liquid will make no difference.
Feb 19, 2008 | Dishwashers
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
326 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
