Question about Honda Electrical Supplies
Hi 6000 watt generator sat for 6 months with fuel shutoff. now will only run with choke on. thanks, Glenn
  • 487 Answers
Hi, sounds like derty fuel, you will need to check and clean air and fuel filters; also wash your carbretta out with lean fuel. Drain fuel tank and replace with fresh fuel.
Posted on Aug 06, 2010
  • 843 Answers
Drain the remaining fuel from the tank Put in just a little fresh fuel mixed with carb cleaner. Run the engine (with choke). Repeat until it runs right. When you store the unit you should empty the tank. Using a stabilizer like Sea-Foam helps the shelf life of gas considerabley.
  • Duane
    Duane Mar 12, 2014
    My 6000 watt Champion Power Equipment generator has been sitting for well over 6 months. I replaced the carb, fuel filter w/petcock, put in new gas and it still lopes. Runs fine with choke on. Starving for gas, but why?
My 6000 watt portable generator will only run 5 or 6 m7nutes and then shut down?
check oil level --fuel--fuel filter--and check if overheating
Oct 27, 2016 | Lands Phones
Generator does not start it has fuel in the tank with new battery ,check every thing is ok
how OLD is the gas? if it is older than 3 months with NO stab condishner get rid of it try new gas
Dec 12, 2013 | Dewalt Generator. 6000 Watt Portable...
Cannot start the generator
when was the last time it ran?
If you didn't run it out of gas the last time you used it and it sat for a few months, the Carburetor is gummed up.
You can thank the wonderful idiots that think Ethanol Gas is a good idea
Jul 13, 2013 | Electrical Supplies
The float bowl their is a drain bolt, take it out check for gas.
Aug 23, 2012 | Dewalt Generator. 6000 Watt Portable...
ONAN GENERATOR STARTS THEN ONLY RUNS WITH CHOKE ON
This sounds like a problem with fuel settings or dirt in the jet.
If you can find the carb adjustment screws, with it runing on full choke - screw it in fully untill it stalls, then back out to original position, then restart.
Take off choke and adjust setting untill it runs well when warm with choke fully out.
You can then try and make it run leaner without stalling.
Feb 07, 2010 | Watts Onan Portable Generator - 4000 ,...
Makita Generator G2800R
Check your tank for contaminants (water, trash, dirt, monsters, etc), as well as the balance of the fuel system. You may also need to remove the carburetor and clean it out, particularly if the generator has sat for more than a month with fuel in it (most do, including mine) and now has deposits. The only thing that the choke does is make the mixture rich by cutting off the air.
And just for grins, look at the spark arrestor screen on the muffler. This can be related and problematic as well.
Mar 10, 2009 | Makita 2,800 Watt 6 Hp Portable Power...
Electrical Supplies Logo
199 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
