Question about Hotpoint First Edition WMA20 Front Load Washer
Can you tell me where the brushes are located in a Hotpoint First Edition WMA 20 please
  • Hotpoint Master
  • 3,463 Answers
Removed lower rear panel of washer.
Undo 2 screws securing motor to outer drum casing, unplug motor lead and remove motor, brushes ar e located at the end of the motor furthest away from the motor pulley.
Posted on Nov 29, 2010
I cant find the filter on the hotpoint first edition wma 20
i had this trouble for ages, u have to tip it on its side or bck as the filter is up underneath
Sep 29, 2011 | Hotpoint First Edition WMA20 Front Load...
How do we empty the filter on hotpoint first edition wma 10?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose, reassmble and test for leaks.
Have some cloths ready to mop up any water that may appear..
Jan 13, 2011 | Hotpoint First Edition WMA12 Front Load...
How do we empty the filter on Hotpoint WMA 12?
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Dec 19, 2010 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition 1000 WM52
I had same problem. Had to replace brushes on motor. Easy enough job to do yourself
Jan 04, 2009 | Hotpoint First Edition WMA12 Front Load...
Hotpoint first edition wma 11 drum bearings removal
Hey kevin that outer cone of the front bearing is a mission im telling ya...
But from experience ive found that by cleaning around it ( i use a metal brush on a drill ) and using wd40 and letting it soak in for a few hours its makes like a lot easier,,
I use a bolster with an end similar to a crow bar to just get inbetween the tiny gap and a very big lump hammer to know out the cone.... Best way knocking it from side to side ie bottom the turn the back half of the drum round and knock the top then the sides,,
hope this helps....
cheers mate..
Jan 10, 2008 | Hotpoint First Edition FEW12 Front Load...
The water will not drain on my first edition wma 10 hotpoint washing machine so does not spin either any clues to where the filter is???????
Most likely something stuck in the pump. Remove front panel and hose that goes into pump. usually you will see the object. if not remove pump and look inside.
Jan 06, 2008 | Hotpoint First Edition WMA12 Front Load...
wma washers (not the computer ones) normally do not have a separate control board, just the one at the top that has the timer dial on it, check for wires off or blown or burnt marks on it, after that check the wires at the motor, without doing multi-meter checks it could still be either i would not suspect the brushes as the motor at least rotates, it could be a blockage in the pressure system pipe, the thin one that comes from the top of the machine (a round item about 2 inch diameter) hope i have helped, if so rate me
Sep 17, 2007 | Hotpoint First Edition WMA20 Front Load...
Cleaning
I am not familiar with this machine's model, but in most of the machines the filter is located under the panel in the bottom of the machine (the panel under the front door). You should pull the panel out and you will find the filter there. Before openning the filter prepare a bowl and a floor cloth to avoid water's flooding. Good luck!
May 06, 2006 | Hotpoint First Edition WMA22 Front Load...
Hotpoint First Edition WMA20 Front Load Washer Logo
188 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
