Question about Cameras
I have a samsung digital camera, model L201.After Switching on shutter is opening but Lens is not coming out.
  • 6,826 Answers
The gear inside the lens is stuck, maybe some grit or sand got in there preventing it from operating.
http://www.samsung.com/us/support/online/supportOnlineServiceRequest.do
The above is a service request to have the camera repaired.
Posted on Aug 06, 2010
When I take pictures with my Samsung L201 there are horizontal lines on the picture when I look at them on the camera or computer
Greetings.
To resolve this problem you need to replace the ribbon cable inside the lens shutter.
For the unprepared person, unfamiliar with the repair of cameras - a difficult task. Such work can perform any repair.
For self-repair is necessary:
1 soldering iron, solder, flux
2 Tweezers
3 Screwdriver, small
4 Device for capacitor discharge flash
5 optics for if poor eyesight
Skills:
1 Reading the manual repair
2 The ability to solder
3 understanding of the mechanics of the lens (you must correctly parse and then properly assemble the mechanical part of the lens)
Flex -
Flex Samsung shutter L201 digital camera
Manual -
Samsung Digimax L201
Oct 03, 2014 | Samsung L200 Digital Camera
Screen is black and pictures come out black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 30, 2011 | Samsung BL103 Digital Camera
No shutter
The shutter can fail to failure of the control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened.The shutter motor/mechanism can be jammed , manually try and release if not check voltage on the motor to confirm the fault.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Jul 28, 2011 | Samsung L110 red Including Charger,...
Canon Digital Rebel
First, try releasing the shutter with the lens off anf the camera set to a long exposure. Watch the shutter through the lens mount to see if it opens all the way. If it doesn't you need a new shutter. This might be covered by Canon's warranty. If the shutter is opening, try to see if something is blocking the CCD. If that is the case, a competent technician should be able to remove the offending piece.
Mar 25, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
289 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
