Question about Epson Office Equipment & Supplies
When my projector is connected my lapton it shows no signal
  • 89 Answers
Choose RGB input in the projector or Press Fn and Screen icon until the display shows.
Posted on Aug 10, 2010
My mac book and epson projector doesn't show the signal
To my knowledge there are no video drivers to output video on a Mac USB port in the Mac OS system. There are however, devices that connect to the USB port that will give video out on Conventional (VGA, DVI, HDMI, etc) connectors.e.g. http://www.newertech.com/products/viddu2dvia.phpMost projectors connect via VGA - what Projector are you using?
Jan 19, 2012 | Apple MacBook Pro Notebook
The SP7205 will only show 480P. I have connected a DVD to the 7205 via composite cables however the unit only shows 480p. How can I get 720p or 1080i?
Unfortunately the highest video signal you'll receive through composite is 480p. To achieve anything higher than the said signal, you'll need to utilize either the component or DVI input of the projector. Those inputs will detect any HD signals.
Also if you've not done so already, you'll need to check the settings of your DVD player to make sure that it's outputting 720p and/or 1080i/p signal. Hope this helps you out.
Aug 09, 2011 | InFocus ScreenPlay 7205 Multimedia...
My DLP projector SIM2 DOMINO D35 is turned on and works normally BUT picture is absent on all of inputs (projector shows NO SIGNAL, green indicators is ON). Sources of signal and cables are in order. What...
It is possible that the last time this was connected there must have been an higher input applied than is recommeded so that the input PRE_AMPS were loaded to fail.
You need to check with an signal trace on the input to find if an OP-AMP has failed or the LOGIC switching IC had failed.
Need to test using a signal tester and meter.
Jul 14, 2011 | SIM2 DOMINO D35 DLP Projector
HDMI inputs do not show a picture. They worked but now do not. They display the setup program from the Onkyo AV receiver via HDMI output, but not when the receiver is pushing any other signal via the...
This is likely a problem with the receiver not the projector. If the setup screen from the receiver is displayed through the projector, then the projector is functional. If the actual signal is not displayed, then the receiver is not sending the signal. The setup screen is generated inside the receiver and is injected later in the video path than the input signal. Try a direct connect from the signal source (other side of the receiver) to the projector. Again, if that works, then the problem is the receiver.
Dan
Aug 21, 2010 | Panasonic PT-AX200U Projector
Connect to a computer to project a slide show
laptop connected. projector on and running. blue screen up and reads "searching for signal" has been doing that since both machines were turned on for thirty minutes. what now?
Jun 16, 2010 | Dell 2200MP Multimedia Projector
Projector does not get signal from my HP DV 6000 Laptop
try pressing FN on your keyboard then press F3 = FN+F3 at teh same time to project waht is in the laptop to the projector........
if not go to desktop right click anywhere select display properties it should give you the option to select the monitor and projectors detected by the laptop to show what is on you laptop as well posbbile u will need to either expand or if the option cloning will be present to have both show on the laptop and desktop ^_^
Jun 04, 2010 | HP Pavilion dv6000z Notebook
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
It shows no signal
Toshiba TDP-S8 projector cannot communicate from my laptop, it shows no signal. how can i fix it? thank you so much...
Feb 19, 2009 | Toshiba TDP-S8 Multimedia Projector
Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Toshiba LCD projector
always make all connections first !! after that : switch on the laptop, or else no detection of an external monitor/projection device is possible.
Please check also your bios settings, some can be set to force simultaneous display of external screen and lcd of the laptop.
some laptops also require ddc communication between external connected devices.
Try to use a full wired ( except pin 9) VGA cable.
succes
Aug 31, 2008 | Radio Shack Cinego D-1000 Multimedia...
249 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
